trianglelaguna wrote:
very nice...where did you get the spoiler....very nice
Found th spoiler on ebay... No idea what it was for, but I was sure it would be the finishing touch when I saw it. Had to make brackets and trim a little to clear the header
BEFORE P{CS- this is they way I brought it home---- basically I got a frame and two recycle bins full of parts. What was not bolted to the frame was loose in bins (nuts, bolts, everything... had to sort what when where from manuals & micro-fiche)
Motor that got rebuild & an 1166 BB kit now. Winter project will be converting back to throttle bodies, but upgrading to modern injectors & probably a MicroSquirt
What a mess - sat 15 years after it quit running -- I never found the cause.
Gas left in tank too -- here's the sender unit & the tank was just as bad, but did not leak -- The tank went to a hot-tank and now coated with a polymer used to seal aircraft fuel tanks.
