Whats the best way to clean up old engines? 01 Sep 2009 19:18 #318395
  • Circle_u
  • Circle_u's Avatar Topic Author
  • Thank you received: 0
I have a couple of old bikes that I can get running, but the cases have become, for a lack of a better word, chalky.
Any ideas on how to clean them up?
Whats the best way to clean up old engines? 01 Sep 2009 19:29 #318401
  • doped304
  • doped304's Avatar
I never have any luck with chemicals. Sandblasting is by far the fastest way, glass beads work good on jugs and cases t]it keeps them shiny. A cheap gun cleaning kit with a variety of bronze brushes and a drill is a good start before more drastic measures are taken.
Whats the best way to clean up old engines? 01 Sep 2009 23:56 #318488
  • donthekawguy
  • donthekawguy's Avatar
  • Thank you received: 8
Read this post. kzrider.com/index.php?option=com_kunena&...=13&id=312886#313311
I had good luck with a wire brush I found at the hardware store and a dremmel. For the brush go to Ace or True Value and look for a set of five brushes. Look for the pack that has one in it like the one in the pic. That is the only wire brush I have found that won't wear out or fall apart in five minutes.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Whats the best way to clean up old engines? 02 Sep 2009 06:20 #318527
  • chance
  • chance's Avatar
  • Life long biker/
All the engine cover can be fine sanded and polished. The fins and block I use brasso and a wire brush and PLENTY of elbow grease. :(
Whats the best way to clean up old engines? 02 Sep 2009 06:24 #318529
  • arai59
  • arai59's Avatar
  • User is blocked
  • Thank you received: 1
This has been posted before but I have the cases and related aluminum parts soda blasted. Cleans up with water. Very safe.
Whats the best way to clean up old engines? 02 Sep 2009 06:27 #318531
  • chance
  • chance's Avatar
  • Life long biker/
Digg the Fro Bro....
Whats the best way to clean up old engines? 02 Sep 2009 07:14 #318540
  • Russ Jackson
  • Russ Jackson's Avatar
Was it done on the bike?...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Whats the best way to clean up old engines? 02 Sep 2009 09:11 #318566
  • aaron3874
  • aaron3874's Avatar
I found that light media or glass bead blasting works good. Didn't sandblast the side covers though - I sanded with different grades of sandpaper until I could polish with compound.
If I could go back, I would have painted the engine after it was blasted to keep from corroding again.
Whats the best way to clean up old engines? 02 Sep 2009 09:54 #318571
  • Sinners Saint
  • Sinners Saint's Avatar
Stupid question, but what is soda blasting? I've heard of bead and sand blasting but not soda blasting.
Whats the best way to clean up old engines? 02 Sep 2009 10:00 #318572
  • Skyman
  • Skyman's Avatar
  • Thank you received: 3
Same principle as bead/sand blasting. Different blast media--plain old baking soda.
The benefit is that it is less likely to cause pitting or scaring, and it dissolves in water, making clean up easier.
With bead/sand blasting, you have to be EXTREMELY meticulous with cleanup to make sure all grit is flushed from interior passages.
West Linn, OR
Whats the best way to clean up old engines? 02 Sep 2009 10:02 #318573
  • Thank you received: 2829
Take a look at this thread on budget soda blasting:
Budget Soda Blasting
Whats the best way to clean up old engines? 02 Sep 2009 10:36 #318585
  • Sinners Saint
WOW! Thats pretty cool, I'm gonna have to try that one out. I have a few projects that need sensitive cleaning done and that looks like it'll do the job proper.
