1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
02 Sep 2011 02:38 #473709 by tk11b40
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
Testarossa,
Thank you for the encouraging advice, I have done just that, AND it appears the wires match perfectly, (the 4). I wish I knew what the others were there for, but guess it does not matter.
SOOOO.. big night..all the electrics are on, and I am confident after referencing the wiring diagram about 3 dozen times, I am hooked up correctlty at least enough to start it. (it ran before) but all this new stuff I had to re-check.
It still looks to be in parts and pieces, but this means the project has come to near end. The stator, regulator/ rectifier, and Dyna Ignition were the last improvements, now it's time to put it all together and ride it.
I just sat in the garage, amidst the mess, and drank a celebitory beer.
It will be a week before I ride it, but dam, there it is ALL there..just need to re-assemble for about the 40th time.
Anybody reading this needs to know there is no better place to get your parts than Z-1 Enterprises, without the stuff they carry, and knowing it's right when you order it, this thing would have been pushed over a cliff long ago..Thanks Z-1.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
02 Sep 2011 10:16 #473747 by 531blackbanshee
Replied by 531blackbanshee on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
awesome spot to be in, congratulations!!!!!!!!!!!!!!!
just sitting there looking at it,knowing that it "should run" when you set it all back together.
definitely a cool spot.
  • mark1122
  • Keep twisting it
02 Sep 2011 12:08 #473760 by mark1122
Replied by mark1122 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
tk11b40 wrote:
u have probably already adjusted this, but i would feel bad if u hadn't, and something happened. :(
so dont forget to reset the rev limiter. 15000 would be hard on the valves and pistons. :(
i set mine as low as it would go and tested it. i could hear it work. ;)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
02 Sep 2011 12:43 #473764 by Prouty
Good job Sfc. Ted! This is as good as getting back from Iraq! HoneyBadgerRacing has a new bike!
If you ain't first, you're last!
02 Sep 2011 13:32 #473769 by 79MKII
Looks awesome! By the way...how do you bend your aluminum...like the 90 deg bend on your ignition mounting bracket? Looks perfect.
The Kaw List:
02 Sep 2011 16:54 #473855 by tk11b40
Thanks for the compliments!
I would be the guy who set the rev limiter too high and blew the motor first day out, when i get back in the garage that is thing 1 to do ..:blink:
Bending Aluminum...cool that you noticed.
I have some experiance with heat treating aluminum, and a little known fact is that it gets real cooperative (generally) at about 900 degrees. I warm it with a propane torch, and just tap with a dead blow, you can tell it's gonna cooperate when the "ting" sound turns into a "thud". This means the little molecule fellas are ready to party.
Problem is you can heat it too much and either just plain melt it, or make it brittle. Play around with the "ting" and "thud" method..I think you'll hear what I mean. I bent the bracket in the bench vise using this method.
Yee-haaaaaw team Honeybadger!!
Ducati S4R
Husqvarna FE 350s
The following user(s) said Thank You: Bad Kaw
02 Sep 2011 16:58 #473858 by mtbspeedfreak
Replied by mtbspeedfreak on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
tk11b40 wrote: Yee-haaaaaw team Honeybadger!!
You should definitely name it Honeybadger!
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • mark1122
  • Keep twisting it
02 Sep 2011 17:02 #473859 by mark1122
Ted, can u get enough heat out a small plumbing propane torch to get a good bend?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
02 Sep 2011 20:56 #473904 by 79MKII
mark1122 wrote: Ted, can u get enough heat out a small plumbing propane torch to get a good bend?
same question for me.
When you bend in the vise, do you hammer the metal to bend it? If so, do you hammer close to the bend?
The Kaw List:
03 Sep 2011 11:58 #474009 by Bad Kaw
Replied by Bad Kaw on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
tk11b40 wrote:
Back to the KZ...
I received all the electrical stuff from Z-1 Enterprises, they are the best!!
Now I have the bike all torn apart again, putting in the new Dyna 2000 ignition. So many wires hanging all over the place, I will be glad when this thing is done.
The install is pretty straight forward, it's just the thought of getting into the wiring yet again.
I fancied up a flat pattern for the Brain bracket and hung it behind the battery box.
Oh man, that's nice!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
05 Sep 2011 04:12 #474291 by tk11b40
Wow the aluminum thing seems ro be a hit.
Ok...
Yes a plumbing propane torch is all I use.
Remember the ting and the thud. Warm the area you want to bend. But Aluminum dissopates heat rapidly, so it takes some patience. The metal never gets real hot, I would say around 900 degrees at most (i.e. it does not change color). Thats why you are heating and hitting with the dead blow at the same time.
Aluminum melts at around 1300 degrees depending on the alloy, this was 6061, it might be a little lower like 1250.
You can melt it with a Propane torch if you concentrate the heat in the same area for too long. Think of it like roasting a marshmellow, too much heat and it is up in smoke.
Try it with a smaller scrap piece first. I have done this a few dozen times.
We straightend castings (when I worked in the foundry) as they come out of "quench" after jigging they go into the age oven. The castings make the same sound when they are real pliable, almost rubbery. When they start to make the "ting" sound we would be losing the battle, and many times would need to run them up in the oven followed by quench again.
HoneyBagder...thinkin the name is gonna stick, long as it is ok with the Team manager (Prouty?)
Ducati S4R
Husqvarna FE 350s
06 Sep 2011 01:52 #474506 by tk11b40
HELP!!
I parked the bike on the street, and after an hour, there was a huge oil slick under it, looks like the shift shaft seal is bad....
Where where where do i find this seal??
Ducati S4R
Husqvarna FE 350s
