My z1000 lives....again!
- StreetfighterKz
02 Jul 2007 19:08
Ok,
So after not running since last year, I got my 1000 running. Part of the reason it took so long is that I had to figure out how to get the hydraulic clutch I fitted to work.
I modded the stock cover for the slave cylinder to fit and trimmed down the clutch pushrod to fit. I went to the local bike junkyard and found a clutch line that was long enough. After not getting the system to bleed I rebuilt the M/C. I still couldn't get the system to bleed because the slave was lower than the M/C of course.
I came up with an idea to bleed the system. I had to remove the exhaust system since the clutch line was routed between it and the frame and taking the line off the M/C or slave would be a step backwards. I left the M/C on the handle bars and hung the slave from the rafters using a tie down strap. Having the slave higher than the M/C allowed the air to work their way up to the bleeder on the slave cylinder.
After about 30 minutes hanging there I took the slave down and clamped the piston using a C-clamp. The reason I did this is so that the M/C would have something to work against and makes the bleeding much easier.
I remounted the slave to the cover, the cover to the engine, and remounted the exhaust using new gaskets.
Turns out that my battery is almost done but a few kicks and the bike fires right up.
I took it around the block and everything seems to work OK. The carbs are overflowing, the shift lever needs adjusted down and some other odds and ends. But she lives!!
I'll get some pics posted in the next few days.
Later,Doug
Later,Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- Mark Wing
Re: My z1000 lives....again!
02 Jul 2007 22:35
I bet that feels great, I'm looking forward to the day I can post the same thing.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Sandy
- Fly High,Tony
- themachine
03 Jul 2007 03:12
mmmm, hydralic clutch....
*drools*
thats pure awsome right there
*drools*
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- StreetfighterKz
08 Jul 2007 14:17
Got some pics after 4 years of not taking any.
Later, Doug
Post edited by: StreetfighterKz, at: 2007/07/08 17:20
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
08 Jul 2007 14:21
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
08 Jul 2007 14:22
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- pyxen
10 Jul 2007 07:54
Wow..I like your z1000 more than your Ducati!
Nice work
Nice work
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- DrWhizBang
10 Jul 2007 09:23
Pure awesome!
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
- StreetfighterKz
11 Sep 2012 23:07
I know this is an ancient thread but I started it and it still pertains to the same bike so...
My z1000 lives some more...
After been sitting for at least 2 years, I had some motivation to get her back on the road.
I swapped in a ZX7 front end which worked out way better than I had planned. I may need some stiffer springs for it but the Zx11C rim and brakes were direct bolt-ons.
I also rebuilt the carbs and got a sealed battery. The bike fired right up within 15 seconds of cranking. No leaks from the carbs and once warmed the bike revved pretty cleanly. I think that the carbs still could use a sync and some fine tuning.
I still need to figure out how to mount the stock Kz gauges and get the front fender back from my buddy who's painting it for me plus some other odds and ends that need taken care of before I can tear up the streets.
Anyways, on to some pics and short video.
Later, Doug
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
12 Sep 2012 13:41 - 12 Sep 2012 13:42
Last edit: 12 Sep 2012 13:42 by 531blackbanshee.
