  • Page:
  • 1
Basket case ‘81 440 28 Mar 2024 06:54 #897007
  • BruceinOH
  • BruceinOH's Avatar Topic Author
  • Thank you received: 2
Good morning!  Earlier this week I bought an “almost” running 1981 KZ440 belt. This is going south quickly as I only have the tank and carbs and already found holes in the tank under the body filler, and a bolt in the carbs where the pilot jet should be, the carbs are also missing one of the mounting rails and the brass needles, drain screws, etc. look like they have been torqued down using a large breaker bar.
Jet kits, drain plug screws and a set of carb mounting rails (thanks EBay!) are all in route. I hope to have a trailer next weekend to get the rest of it.
I wanted a project, looks like I got one!
I will start a post on my progress soon.
Bruce
Basket case ‘81 440 28 Mar 2024 07:36 #897010
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Welcome to KZRider
Have fun with that project
Basket case ‘81 440 28 Mar 2024 07:43 #897012
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2680
I might have some carb cores if you are in need.  They are missing parts, but the bodies seem okay.
And remember, there is much more to rebuilding a set of carbs, than installing aftermarket "carb kits" in them.  All the internal passages need a deep cleaning, after breaking down the set and removing all the soft plastic parts.
Good luck.
PS: when posting photos here, be sure to click "insert all" before posting.  That puts the image into your text, instead of linking a tiny thumbnail image.
Basket case ‘81 440 28 Mar 2024 08:06 #897016
  • BruceinOH
Thanks for the welcome and advice.
My plan was to ensure I can get the new pilot jet to screw in and seat correctly, then do a full teardown. I am hoping I can “borrow” the ultrasonic at work for an initial clean.
Thanks again!
Basket case ‘81 440 29 Mar 2024 16:50 #897062
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Welcome Bruce.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Basket case ‘81 440 30 Mar 2024 05:29 #897068
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
Welcome from GA. It sounds like the previous owner was a good example of the "DPO".
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Basket case ‘81 440 30 Mar 2024 06:06 #897071
  • BruceinOH
That is funny.
My understanding is he bought the bike from a friend.  The PO never got it running and now it is my turn!  Parts start showing up today…
Basket case ‘81 440 01 Apr 2024 05:00 #897127
  • ThatGPzGuy
That is funny.
It happens. My KZ400 came with an airbox built out of PVC pipe with a lawn mower air filter.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Basket case ‘81 440 01 Apr 2024 05:53 #897130
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
That is funny.
I wonder how many minutes of r&d went into that contraption?
  • Page:
  • 1
