  • Page:
  • 1
  • 2
1973 Z1 owner from North Carolina 17 Jan 2024 08:27 #894078
  • Totaldirtbag
  • Totaldirtbag's Avatar Topic Author
  • Thank you received: 1
Hi, I'm new to the forum but not new to motorcycling or Z1. I have a few bikes including 1975 BMW R75 and a 2008 Harley Springer. I look forward to contributing and maybe getting some help on an ongoing problem with the Z1. Although the problem relates to extremely rich running I believe I have eliminated the Carbs. Let me know what technical forum I should go to and  open up a dialog. It looks like there are some knowledgable folks out there so thanks in advance.
1973 Z1 owner from North Carolina 17 Jan 2024 12:16 #894095
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1983
Welcome to KZRider
 Lots of great help from our membership
Nice Bike
The following user(s) said Thank You: Totaldirtbag
1973 Z1 owner from North Carolina 17 Jan 2024 12:18 #894096
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1884
Welcome from the UK
1973 Z1 owner from North Carolina 17 Jan 2024 12:52 #894102
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 305
Welcome to KZRider.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
1973 Z1 owner from North Carolina 17 Jan 2024 13:05 #894103
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1041
Yes, welcome!  Have you rebuilt your choke plungers?
1973 Z1 owner from North Carolina 17 Jan 2024 18:24 #894116
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 93
Choke plungers would be guess also. I normally replace them when I work on a set.
The following user(s) said Thank You: hardrockminer, Totaldirtbag
1973 Z1 owner from North Carolina 18 Jan 2024 04:16 #894124
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 652
Welcome to The aZylum, our little interwebs corner of motorcycle madness.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
1973 Z1 owner from North Carolina 18 Jan 2024 06:10 #894129
  • Totaldirtbag
Thanks for the suggestions.
After playing around with the carbs for months I sent the set to a specialist. He inspected and concluded that they were set very close to perfect. The final test was a road test on his test bike (lots of tests in that sentence) all ok. Compression 120 on all pots.
Timing  (cam and Ignition) as close to spot om as I can get it. New coils and "wired George" modification to ensure solid 12V+ at the coils. Spark checked with a tester and jumps a gap to indicate better than 20KV.
All 4 plugs soot up very badly within 2 minutes running. It sounds great until then.  I just know its going to be something stupid that I have overlooked. If anyone knows of a "great" mechanic in or around the Carolinas I would be interested.
1973 Z1 owner from North Carolina 18 Jan 2024 07:11 #894133
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 167
Nice looking Z! Food for thought. Quick question though, is the engine out NOW or is the pic of completeness a re-install? I have some info on the carbs if it helps the "rich" condition. Pertaining "only to the carbs" though, i do a lot of the ramp style 72-75 Z's. Are You close to Asheville, NC?
1973 Z1 owner from North Carolina 18 Jan 2024 09:55 #894138
  • Totaldirtbag
Hi,
I am in Wilmington NC so its quite a way from the mountains. The bike is all together and I don't know how the pic of the engine got attached although I probably selected it by mistake. I would like the info on the carbs .... you just never know if you are missing a piece of the puzzle. The fact that all the plugs foul at the same rate and so quickly leads me to think I'm missing something obvious. Particularly since they worked fine as a set on another Z1. I don't think its a fine tuning issue but likely to be a component failure or I have hooked up something wrongly. There cannot be too many issues that affect every cylinder in exactly the same manner. It seems I am going round and round in circles on this one and its not as if I am inexperienced. Iv'e been working on my own stuff for over 50 years and never been stumped like this. I will (for the 100th. time) remove the carbs and clean and inspect the choke plungers etc. as some of the members have suggested. I' m leaving on a 10 day trip shortly so may not have a chance to do much till I get back. Thanks for your input, I really appreciate the willingness to help.
1973 Z1 owner from North Carolina 18 Jan 2024 11:10 #894149
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
Did your carb guy tell you what the internal parts sizes are. Telling you the are close to spot on is subject to the carb guy looking up the correct carb rack to compare yours to. Before any information can be given the forum will need to know the current setup.
Last edit: by Mikaw.
1973 Z1 owner from North Carolina 19 Jan 2024 03:34 #894162
  • asphalt900
Things to consider. Saturated pleated air filter if installed, plugged vent tees (those little whitish barbs fittings (2) for starters. By fouling do You mean the "look" sooty or does the Z quit running? Did you clean the plugs to their original color for comparison between tests?
  • Page:
  • 1
  • 2
