Quick introduction 21 Jul 2016 17:41 #735772
  • CoxUSMC
  • CoxUSMC's Avatar Topic Author
  • Thank you received: 1
Hello, I just wanted to give a quick introduction about me and my bike. I inherited my grandmothers property in January and while going through one of the barns I came across 5 bikes, all late '70s. Two kz400s, a Honda 400, a Yamaha enduro, and a 77 kz1000 ldt. After getting in contact with some of the family I was able to get the titles for the zks and Honda. For almost two weeks now I have been working on the KZ1000 and this site has been a huge help! Thank you all! I am OPEN TO ANY ADVICE yall may have on getting this bike up and running, it has a 900cc DOHC engine in it, it has been parked for 20+ years, and doesn't have keys.
77 kz1000 with a Z1-KZ900 motor
Last edit: by CoxUSMC.
Quick introduction 21 Jul 2016 18:31 #735775
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2624
Welcome, what makes you think it has a 903 engine in it?
Quick introduction 21 Jul 2016 18:42 #735777
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
  • Thank you received: 87
I picked up one of those recently, when reaching up under the seat with a #10 swivel socket to remove the seat latch I let my girlfriend do it with her little hands and a long extension but blew it when I said SPIDERS!! :woohoo:
Last edit: by 9er rider.
Quick introduction 21 Jul 2016 18:44 #735778
  • SWest
  • SWest's Avatar
  • 10 22 2014
:lol: :lol: :lol:
Quick introduction 21 Jul 2016 18:51 #735781
  • CoxUSMC
The man who parked it told me he put a 900 bored over put in and the 1st 3 on the engine are Z1E
Quick introduction 21 Jul 2016 18:54 #735782
  • Thank you received: 2829
Welcome aboard! Nice bike! Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits, and picture 6 shows a comparison between Philips and JIS bit tips.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
PICTURE 6
Attachment JISvs.PhillipsAngles-2-3-4-5-6-7.jpg not found
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
The following user(s) said Thank You: CoxUSMC
Last edit: by 650ed.
Quick introduction 21 Jul 2016 19:02 #735784
  • azman857
  • azman857's Avatar
  • Thank you received: 111
Welcome to our corner of the WW Web. Happy wrenching on your bikes. What a find!. Thank you for your service. Being from Tulsa I know there are some great rideing roads in OK.
Quick introduction 21 Jul 2016 19:25 #735789
  • SWest
  • SWest's Avatar
  • 10 22 2014
Can't see the numbers. On the bottom front of the barrels it should say 903 cc.
Quick introduction 21 Jul 2016 20:18 #735794
  • CoxUSMC
swest wrote: Can't see the numbers. On the bottom front of the barrels it should say 903 cc.
Roger that, I will check when I get home and let you know in the AM, thanks Steve!
Quick introduction 21 Jul 2016 20:27 #735795
  • CoxUSMC
Another question: I was told it is an 1980 Ltd, but from the wiring and the frame I'm pretty sure it is a '77. How can I know 100% since it doesn't have a "full" VIN?
Quick introduction 21 Jul 2016 20:32 #735796
  • SWest
  • SWest's Avatar
  • 10 22 2014
That is a KZ 1000 frame and it does say 77.
Quick introduction 22 Jul 2016 08:07 #735839
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
The decal states that it was built 10-77. It may be an early '78 model as bike manufacturers (like the car guys) start new model production before the calendar year begins.
