New from maine! 01 Jul 2015 18:09 #679021
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
650ed wrote: If your bike really is stock and in good condition it's a shame to mess up a nice survivor. I see this in your future.
Attachment apes-2.jpg not found
:laugh: :laugh: :laugh:
Like I said in another thread with this pic. It makes a statement, I just don't know what and my daughter thinks they're stupid.
New from maine! 01 Jul 2015 21:17 #679057
  • Slopar00
  • Slopar00's Avatar Topic Author
  • Thank you received: 0
Still no luck.. I just go to add attachment right?
83 kz 440 bobber build. It's my 1st bike/ build I've ever done so it's coming along slow.
New from maine! 02 Jul 2015 04:45 #679077
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Maybe the photo is too big? Here's a topic Patton posted --- it's a sticky in the About the site section of KZR. Be sure to click the Insert button. KZRider --- Posting pics is easy
Photobucket, Flickr & Imgur are handy for storing photos & you could use links to provide pics.
Last edit: by martin_csr.
New from maine! 02 Jul 2015 05:01 #679080
  • SWest
  • SWest's Avatar
  • 10 22 2014
Can we say moron? :lol:
New from maine! 03 Jul 2015 08:07 #679233
  • Slopar00
So if I was going to do 12-14" ape hangers does anyone know what I'd be looking at? I figure longer cables and I'd have to splice in some extensions for wiring. Anything else?
Is there any kind of maintenance I should be looking into for the belt drive set up before my first ride?
Last edit: by Slopar00.
New from maine! 03 Jul 2015 08:27 #679236
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2073
If your switchgear has locator tabs, then you will most likely have to drill holes for them, as I suspect any ape hangers you find will not be model specific.
Check the belt for frayed fibers and cracks . Check the pulleys to be sure the "teeth" have square shoulders and that any evident wear is even all the way across. Be sure the belt is properly adjusted for slack, in accordance with the fsm. With the bike on its center stand and the transmission in neutral, the rear wheel should turn easily, with no squeaking, uneven tension, or waves, wiggles or woogies in the belt.
Last edit: by TexasKZ.
New from maine! 03 Jul 2015 18:53 #679321
  • Slopar00
Thanks tex! I'll have to check those things.
New from maine! 03 Jul 2015 19:19 #679326
  • SWest
  • SWest's Avatar
  • 10 22 2014
The handle bars have to be 7/8". Most are 1". Being that long they could bend easily.
New from maine! 04 Jul 2015 04:19 #679355
  • Slopar00
Well that makes things a bit more difficult. Thanks !
New from maine! 06 Jul 2015 17:37 #679752
  • Slopar00
Does anyone have a pn for a gel cell battery for a 81 kz440? I'm going to look into buying one for my bike eventually.
New from maine! 06 Jul 2015 20:23 #679820
  • Slopar00
What's the difference between solo eat springs?
New from maine! 07 Jul 2015 07:00 #679890
  • martin_csr
BatteryStuff.com has Scorpion AGM batteries. search: KZ440 agm battery.
Partzilla will have some battery info & if unsure of what's needed, you can probably check the Yuasa site to verify the size.
