Search Results (Searched for: gs swing arm)
Replied by CruisingRam on topic GSXF Katana Front-end/Swingarm swap?
04 Jan 2006 22:53
The GS 1100 E is a direct swing arm bolt in- but still needs alot of modding to get it to work- have to re-route brake stuff, everything also depends on what rims you wish to use.
How good with a welder and how much of a fab guy are you?
I think it is do-able if you have some skills.
Replied by 80sDweeb on topic GSXF Katana Front-end/Swingarm swap?
04 Jan 2006 22:51
I asked the front end question a long time ago, and I saved the answers I got in a text file:
These were both from the old site. The 600 and 750 Kats have the same frame and suspension parts. If you do go for it, try to get as much as you can for your money (pivot bolt, brake hoses, maybe even rear brake master, wheels and tires, guages) whatever you can get away with. Depending on what you get, that can be a good deal.
As for the rear, as far as I know the width of the swingarm pivot point is your biggest problem, and I think the Suzukis are narrow enough to fit our bikes. You'll likely have to get bushings made to fit, or find some other custom bearing solution for the pivot, but I bet the swingarm will fit. I can't remember if I've seen any successful Kat swingarm swaps, though. I looked pretty hard, and didn't find one. I find the idea attractive, though, because so many of these bikes sold, and they're not as popular as the GSXRs for swapping, so the parts are cheaper.
ANSWER #1:
Get to know a machinist well!
Mine knows me by name! The katana 750 front end was easy honestly, the stem had to be extended about 7/8" and the bearings I happened to have laying around (quite a few bikes and parts laying around) But that is all it was for thicker forks and floating disks, and four pot calipers.
ANSWER #2:
The katana front end was mounted by extending the katana stem by 7/8" (I think) and then using the top bearing from a kz650 tapered bearing kit and the bottom or top from a gs500e, that I had laying around the shop. They just sorta fit. It was more coinscidence than me knowin my shit. Just don't be afraid to try some stuff and you'll come up with a great project. I don't really have any pics of the in between stuff, but I will get close up of the rearsets as soon as I can ( I don't own a d-cam). I hope this helps abit. Any other questions please ask.
Bdog
Replied by mpaquet4 on topic GSXF Katana Front-end/Swingarm swap?
04 Jan 2006 21:50
Thanks for the reply sir. I was considering just pressing out the katana steering stem and replacing it with the 650 unit.
As for the swing-arm, I've read so much about the GS, GSXR, swaps that I thought someone may have hands on experience with this swap specifially. I don't know that the pivot points measure similarly, though I thought it strange for a manufacturer to switch up dimensions in such a foundational area from model to model with-in the same family. I have seen stranger things, but I guess I thought with all the posts in the archives on the topic that someone would know undoubtedly...
Wasn't there a post somewhere of a cross-manufacturer bearing chart including steering heads? I thought it had the steering head bearings grouped in families that included all the manufacturers...
Replied by twowheeledterror on topic best ninja wheel for gs swingarm?
04 Jan 2006 19:42
Whatever you get you better match it in the front.
best ninja wheel for gs swingarm? was created by 77KZ650
04 Jan 2006 19:29
Hi, just wondering what I should go with for a rear wheel/tire for my 650 which is getting the gs1000 al. swingarm (if i can find one on ebay, or somewhere else this spring). I want to get something wider than stock, and was thinking about a ninja wheel setup, converting to a disk brake in the back. any suggestions? something like this?
cgi.ebay.com/ebaymotors/95-kawasaki-zx6r...QQrdZ1QQcmdZViewItem
thanks
thanks
Replied by steell on topic GSXF Katana Front-end/Swingarm swap?
04 Jan 2006 15:48
I deleted a few posts that added nothing to the thread.
Both the front and rear are not a bolt on swap, but both front and rear are popular mods to the 750 Turbo's.
All Balls provides different steering head bearings for front end swaps, so you might want to give them a call after you find out what bearings the 650 takes and what bearings the GSXR uses. On the rear it will obviously require some cutting and welding since you are converting to monoshock, and probably have to do some mods to get the swingarm to fit.
If you want to make it fit, then it will, as an example, I swapped a GPz front and monoshock rear onto a KZ750 twin with GPz900 bodywork. :laugh: :laugh:
Replied by twowheeledterror on topic GSXF Katana Front-end/Swingarm swap?
04 Jan 2006 14:07
mpaquet4 wrote:
Well, there's a fine line between pessimism and realism.
Realistically, like I said, chances are slim to none that they will bolt right in.
Have dude measure them for you. Not too hard to take a tape measure and check.
I know measuring is ideal, but those items are now 55 miles away, and I'd like to make one last trip...any way if anyone else has any knowledge of these items working in a swap please let me know...No pessimists please.
04 Jan 2006 13:18
04 Jan 2006 12:47
mpaquet4 wrote:
Chances are no and no.
With steering you will definitely want to be as precise as possible.
With the swingarm chances are good that it's not a direct fit and you'll need to mod one thing or another to get it in and use it.
Get measurements. That's the best way to check.
I have a 1978 KZ650b in my dining room right now minus front-end and swinger. I talked to a gentlemen with a 92 GSXF Katana 750 today who will sell me the swinger (w/brakes, shocks, linkage, wheel etc.) and the front end (w/brakes and wheel) for a whopping 350 bucks. Does anyone here know by chance, if these items will swap readily? I'm aware of the welding necessary for the mono shock set-up, and brake master etc. Just wanted to know if the swing would fit (with-in reason) and if the steering head dimensions were close (bearing sizes)....Thanks for your time in advance...
PS I have archived this topic but found little on these particular items being utilized.
GSXF Katana Front-end/Swingarm swap? was created by mpaquet4
04 Jan 2006 12:34
Displaying 7111 - 7120 out of 7224 results.
