Search Results (Searched for: gs swing arm)
Replied by wrenchmonkey on topic what to check
17 Jun 2016 00:27
Okay, you asked, so this is what your manual for the 1978 KZ650 says to do every 10k kilometers (6k miles):
It's not everything you may want to do but it's a good start..
Check, adjust brakes (C model has disc brakes, check calipers moving freely, grease pins)
Check, adjust clutch
Check, adjust carburetors (this may involve synchronizing, at least I did for peace of mind)
Check, adjust throttle cables
Check spokes and rim runout (you have a C model so you have alloy wheels so visual inspection)
Clean fuel system (inspect tank internally too)
Clean, set spark plug gaps
Check brake fluid level
Adjust camshaft chain
Check, adjust points, timing
Check valve clearance
Check steering play <- this may be cause of speed wobble
Tighten bolts and nuts
Check tire pressure and tread wear <- possible speed wobble cause
Check drive chain wear (observe sprocket teeth for "shark finning" - my term for worn out sprockets)
Clean air cleaner element (Change it every 6k miles)
Perform general lubrication (don't forget the grease nipple on swing arm, it's kinda' hidden)
Change engine oil
Change oil filter element
Lubricate drive chain
Check, adjust drive chain (how far back on adjustment span is it already?)
Check brake wear (disc brakes again, so visual pads, my rear pads were almost worn out at 17k miles)
Change fork oil <- possible cause of speed wobble you mentioned
Lubricate the timing advancer
Change brake fluid (every year or 6k mi)
Lubricate swing arm (every year or 6k mi)
Regrease wheel bearings (every 2 years or 12k mi)
Regrease speedo gear housing (every 2 yr or 12k mi)
Regrease brake camshaft (every 2 yr or 12k mi) - drum brake rear but you have a C so follow for disc brake maintenance.
Lubricate steering stem bearings (every 2 yr or 12k mi)
There's many other things to consider since the bike has been pulled out of long term hibernation. Things like check and clean all electrical connectors, contacts and roll the fuse links is one such example (battery disconnected is probably wise here). The gas tank inspection as it sat so long it may be oxidized and will F-up your carbs quickly if there is no fuel filter. The fork seals are probably in need of replacing just for age. Replace the tires as soon as you can if they're not new already (you only got two and don't want a blow out...ever). Clean the engine and carefully clean out any dirt from the cooling fins. Quad-zero steel wool is good for shining up chrome after a wash and dry. Lubricate the seat pins and latch.
Begin buying new parts - shim kit, wheel and steering bearings & gaskets for engine - cover gaskets that you'll want to replace when you check timing, valve lash etc. It's almost certain that the bearings are original and they're inexpensive so why not replace them during next maintenance cycle. Buy these things as your budget permits but do it sooner than later so you'll have them ready should a problem be discovered and this way you won't be "down" for a week+ waiting for a gasket...
I've done this twice since Feb this year. Once on my 550a (got it as a running bike) and once on my 650-C during restoration. Until you've done all these things (and a few other things, I've already forgotten) you won't know what's going on with your new bike if it should misbehave or develop any issues.
Good Luck and Let the Good Times Roll !
Change engine oil
Replied by TexasKZ on topic what to check
16 Jun 2016 19:23
Absolutely not true about the valves. They need to be checked regularly. Typically, the lash gets smaller over time, finally leading to poor running and burned valves, not extra noise.
That wobble can be caused by bad tires, worn or improperly adjusted steering stem bearings or swingarm bearings. If the tires are more than five years old or are showing signs of cracking, they should be replaced.
No matter what, you should get a genuine Kawasaki factory service manual for that exact model, and some basic tools so you can perform ALL the routine maintenance. That way you can be confident that it was done properly.
The 650 is a good, fun, well built bike and will provide many happy adventures with just a little regular care.
Replied by 650ed on topic Old KZ, new rider
15 Jun 2016 13:55
Welcome aboard! Nice bike! The tach is probably fine. It is more likely that the tach cable has a problem.
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits, and picture 6 shows a comparison between Philips and JIS bit tips.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
PICTURE 6
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
PICTURE 6
Attachment JISvs.PhillipsAngles-2-3-4.jpg not found
MOTOR OIL
So I have a 1977 Kz1000, (1.) I'm looking to 'modernize' the suspension but also keep the twin shock setup. I have a 96-99 katana swingarm, its originally a mono shock. I know I need to make mounts and spacers and few other things to make it work. Could you walk me through on what you would do? (2.) Would a Gsxr swingarm (the older ones, similar to the katana) be better/easier? They seem better built, and a little more appealing to the eye.
Either way, they katana swingarm only cost me about 30 bucks, so not much of a loss.
A gsxr swingarm like this ^ this is also my ideal look for my bike.
Attachment e21a1c27151d8a3328fe7eb5de0c326d.jpeg not found
Replied by 650ed on topic New Rider, First Bike, 1997 KZ1000P
13 Jun 2016 04:41
Welcome aboard!
MANUAL
TOOLS
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike decades ago, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
Replied by larriken on topic Kiwi Z1R
11 Jun 2016 23:55weales wrote: Hey there Larriken, I'm another K-one W-one and am 98% through my '78 Z1-R resto. Just some final fittings to go on - instruments, headlight, fairing and we're ready to roll. (I've been posting my project progress on this site also)
Hope to have photos of the finished article on here next week.
Your challenge has been immensely more difficult than mine and I admire your work and determination!
Mine will never be concourse or original as it has a '79 Z1000 A3 MKii motor (as bought) but will be good enough to enjoy and be proud of (considering what it was like when I bought the basket case 4 and a 1/2 years ago!)
I did see a '78 Z1-R for sale recently in "original condition" (has a modified swingarm and probably other non-original stuff at a dealer in Victoria for $AUD 17,500. Mine has cost me not quite that much, but over nearly 5 years hasn't been too much of a drain on the pocket.
Sweet that you are getting near fnished mate. I reckon I have about at least 70 years to go lol :lol: :blink: Fire up a pic, would love to have a look at your bike.
Replied by 650ed on topic Newly acquired KZ400
09 Jun 2016 14:22
Welcome aboard!
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
Replied by weales on topic Kiwi Z1R
09 Jun 2016 04:59
Replied by 650ed on topic New rider, First bike, 1979 kz650
07 Jun 2016 09:52
Welcome aboard! KZ650's are great bikes. Here are some tips that you may find helpful:
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
Replied by SWest on topic Top Gun GPz900r for sale! Or is it?
06 Jun 2016 07:48z1kzonly wrote: No! your all wrong! Here is the real "top gun movie bike" :laugh: :laugh:
this same ad has been on craigslist 2 or 3 years now. Even the same pictures!
I am sure he is just referencing to the same model cycle in movie!
I'd buy it for a $100 maybe for an ebay parts inventory sell.
It even comes with a table saw :laugh: :laugh:
"Need money for spell check program" :laugh: :laugh:
buffalo.craigslist.org/mcy/5619273021.html
Hell, I'd buy it for the swing arm and sell the rest. :whistle:
Displaying 1001 - 1010 out of 7257 results.
