- Thank you received: 319
Zukey Lake wrenchfest May 17th
- Wheelhop
20 May 2024 07:35 #899366
by Wheelhop
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
Replied by Wheelhop on topic Zukey Lake wrenchfest May 17th
Thank you to Dirk, Matt, and Mike for all your help this weekend. Looking forward to getting back together soon!
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
The following user(s) said Thank You: Street Fighter LTD, Bogie1
- Thank you received: 2280
20 May 2024 07:36 #899367
by Wookie58
Replied by Wookie58 on topic Zukey Lake wrenchfest May 17th
The following user(s) said Thank You: Wheelhop
- Wheelhop
29 Jun 2024 20:11 #901516
by Wheelhop
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
Quick update on our project 1974 Z1 900 engine build. Case / thread repairs have been completed successfully. Thanks to Matt "Mikaw" and Mike "Bogi1" for spending a good portion of their Saturday working on my engine case. Looks like we will be trying to get together again in August to complete engine assembly!
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
- Thank you received: 2057
29 Jun 2024 20:34 #901518
by Street Fighter LTD
Replied by Street Fighter LTD on topic Zukey Lake wrenchfest May 17th
- Thank you received: 1918
30 Jun 2024 09:53 #901533
by Mikaw
Replied by Mikaw on topic Zukey Lake wrenchfest May 17th
Jim, you’re welcome. I’m learning a lot about the upper/lower cases by hands on in-depth investigation. AKA how deep can you drill and not break into the crankcase. Were the oil galleries run and making sure they dont get compromised. We drilled and taped for 12/ 10mm-1.50 helicoil by 25mm installed depth. Here’s where I need some help. Yesterday away from all my parts catalogs I researched the net looking for head stud length and position. Findings were all over the map. From Partzilla the four inner studs have two options 92004-1002 @10 x 190, and 92004-1004 @ 10 x 133. No way that can even be close to correct. See photo for part number 1 in this screenshot. Same for studs at location 3 of breakdown. Calling out the same options.
At mikes house we had studs that were about 190mm, 183mm, and 156mm, I called home and had my son measure studs I had just removed from a ‘76 Kz900 case and they confirmed we had the correct lengths in hand just no confirmation of correct placement. This morning consulting my parts catalog., I get some more backup and additional confusion. They call out the four center studs as 92004-045 @ 198mm. If you type in “Kawasaki 92004-045 into a search it brings up that number has been superseded by 92004-1002 @ 167mm. But if you refer back to my first screenshot and look up part 92004-1002 is says they are 190mm. HELP!!!
30 Jun 2024 10:57 #901538
by Wookie58
- gd4now
- Denco where did you go?
- Thank you received: 429
01 Jul 2024 07:45 #901590
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Zukey Lake wrenchfest May 17th
Not sure this will be of any help but here is what Kawasaki.com indicates, just like the info you have found to date.
1977 KZ650 B1
01 Jul 2024 14:56 #901621
by Mikaw
I don’t find any sizes from parts breakdown that make sense.
position 1. 192mm OA 164mm installed
2. 183mm 150mm
3. 159mm 129mm
there is approximately 30mm engagement into the upper case. None of the sizes called on in the parts fishe make sense.
2. 183mm 150mm
3. 159mm 129mm
01 Jul 2024 15:22 #901623
by Wookie58
Ageed, how can there be two options for the same motor in the same position that are 34mm different in length ???????
01 Jul 2024 16:18 #901629
by Mikaw
It’s more, they are saying you have two length options for the same position 190mm or 133mm that 57mm difference. 133mm I thought might be the installed length but that’s actually 164mm. +-Ageed, how can there be two options for the same motor in the same position that are 34mm different in length ???????
02 Jul 2024 00:05 #901644
by Wookie58
Whether it's 34mm (CMNSL) or 64mm (Partzilla) I still don't understand how there can be "so much" length difference for the same location in the same motor !!! The installed length makes sense but then why two different part numbers !!! I would love to understand this as I am intrigued
- gd4now
02 Jul 2024 09:29 #901662
by gd4now
1977 KZ650 B1
Agree this just does not make any sense. 57 mm (about 2.2 inches) difference in length. I too would like to know how this works.
1977 KZ650 B1
