Kz1000J Rear Seat Cowl
- Vintage3
18 Dec 2022 17:24
Hi,
Just wondering does the rear cowl behind the seat after the two bolts are removed pull to the front or back of the bike for
removal? Need to swap a turn signal. Any tips would be appreciated. Want to be careful with the paint! Thanks in advance.
- Warren3200gt
Re: Kz1000J Rear Seat Cowl
18 Dec 2022 21:32
Two bolts under the seat then lift the rear edge above the lens slightly and then backwards.
There is a rubber block that's part of the tail light assembly that locates into a moulding on the underside of the tail piece. The block is a wiggle fit and supports the rear end of the tail piece.
The following user(s) said Thank You: Vintage3
