  • Page:
  • 1
3D Printed a Tail 10 Aug 2021 14:37 #853526
  • BigTex
  • BigTex's Avatar Topic Author
  • Thank you received: 16
Thought some of you might find this interesting.  I'm playing with an 82 1100 Shaft and of course painting it up like an ELR.  I can paint the bodywork green and add stripes, but this model doesn't have a tail fairing, and it just doesn't look ELRish without one.  So I fired up the 3D printer and made one.  Pretty neat, we'll see if it holds up.
The following user(s) said Thank You: JR, martin_csr, howardhb
3D Printed a Tail 10 Aug 2021 15:13 #853531
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
Howdy.  What material did you go with? Just curious.
Last edit: by martin_csr.
3D Printed a Tail 11 Aug 2021 02:17 #853549
  • BigTex
This is ABS (Hatchbox).  Took a lot of learning to get it printing successfully, but I knew the standard PLA would not hold up.
I just picked up some TPU and plan to try some parts in that - more rubber like.
The following user(s) said Thank You: martin_csr
3D Printed a Tail 11 Aug 2021 03:20 #853551
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 630
I imagined that a tail would look good on a KZ1100A, and this adaptation confirms it.
If possible, please post a couple pics of the entire bike...
1982 KZ1100-A2
3D Printed a Tail 11 Aug 2021 05:47 #853560
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 595
What printer?
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
3D Printed a Tail 12 Aug 2021 14:19 #853653
  • BigTex
Ender 6 printer
As it sits today, still a lot of work (which is the whole purpose, this is just for fun)
The following user(s) said Thank You: rstnick, slmjim+Z1BEBE, martin_csr, BCScott, howardhb
3D Printed a Tail 16 Feb 2022 06:09 #862452
  • Ian_B
  • Ian_B's Avatar
  • Thank you received: 12
A tail definitely suits the bike!
All of the 3d printing that I've seen so far has had a fairly ropey surface finish; the end result of yours looks great. Did you use a filler on the final printed item, and if so, what did you use? Plastics are gnerally hard to get stuff to stick to them.
Ian
3D Printed a Tail 16 Feb 2022 07:12 #862456
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 431
Nice work indeed!
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
3D Printed a Tail 25 Feb 2022 10:10 #862910
  • BigTex
Ian
Printing is in ABS, pretty slow with a small layer setting.  Then a whole bunch of sanding before painting.  No filler, but I would bet an experienced body worker could do it better and faster with some filler.
Last edit: by BigTex.
  • Page:
  • 1
