  • Page:
  • 1
Seat vs tail fit (1981-1984) 09 Jul 2021 14:59 #851518
  • Claude.
  • Claude.'s Avatar Topic Author
  • Thank you received: 34
I recently got a 1982 1000J and I'm wondering about the fit of seat vs seat tail.
Once the seat is correctly installed, I can measure a ~ ¾ in. gap into which I can easily insert my fingers (see pic below).
Is this normal?
I question about a 1982 1000J but I believe the same question could also refer to 1981/1983 1000J, 1981/1982 GPZ1100, all ELR, 1983/84 KZ750L and 1984 KZ1100R. as they all have the same styling and tail piece.
Thanks a lot!
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
1982 KZ1000J2 (another one!)
2017 Yamaha FZ07
Seat vs tail fit (1981-1984) 09 Jul 2021 15:16 #851519
  • Ojisan rider
  • Ojisan rider's Avatar
  • Thank you received: 63
 I have 82 KZ/GPz and currently, fighting just the opposite and I know the reason why. I need to bend my seat rail down a bit. But from what I can remember, gap was little less than that. I think mine was somewhere between 1/4~1/2" at most. For lack of a better word, I had to grab rear top of the seat to remove the seat.
The seat does have couple rubber dampers under it. maybe you can trim just the little? BTW, These seat have hook at the rear of the seat frame, so make sure the hook can catch the square loop and lock the seat.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
The following user(s) said Thank You: Claude.
Seat vs tail fit (1981-1984) 13 Jul 2021 16:52 #851690
  • Claude.
I already gave a look at the rubber dampers and I can’t really trim them for two reasons:
1- the edges of the seat would touch the frame seat hooks
2- the seat bracket’s hooks would be too low after the seat is latched (and the seat would be loose)
The seat have been fitted with a non-OEM cover and I believe the problem I have is caused by an excessive tension that lift up the rear section of the seat...
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
2017 Yamaha FZ07
Last edit: by Claude..
  • Page:
  • 1
