Refinishing GPz550 Side Cover with spotty paint
  • srsupertrap
  • srsupertrap's Avatar Topic Author
12 Jul 2020 08:13 - 12 Jul 2020 08:20
#830454
Picked up this ratty side cover up on Ebay for $10 because it had an emblem . Going to refinish it. The top of the side cover has bare plastic with splotchy remains of paint. What is the best method to knock the cobbled surface down and get it ready for primer?
Thanks
1981 KZ550 D1
Last edit: 12 Jul 2020 08:20 by srsupertrap.
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: Refinishing GPz550 Side Cover with spotty paint
12 Jul 2020 11:00
#830465
Probably 400 grit sandpaper, but only after you wash it really well with soap and water. You don't want to embed any contaminants in the paint. Otherwise, you may have adhesion issues with your primer.
Make sure to remove any loose paint before you primer.
320-400 grit finish is usually used before primer to increase adhesion. Some will recommend 800 grit.
Read the data sheet on your paint system.
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: srsupertrap
  • Nessism
  • Nessism's Avatar
12 Jul 2020 13:29 - 12 Jul 2020 13:30
#830474
Hi Steve,
Sandpaper for sure but not 400 grit unless you got hours of time for sanding. I'd go with 220 or even 150 or thereabouts. Don't sand too deep into the plastic otherwise it will take more layers of primer to fill the scratches. I like to remove as much paint as possible before priming. It takes longer but lower film build is a good thing.
Last edit: 12 Jul 2020 13:30 by Nessism.
  • srsupertrap
14 Jul 2020 06:23
#830638
Hey Ed & F64,
Thanks for the advice on sanding the side cover. I will get to work and start sanding and report back.
1981 KZ550 D1
  • Deuce
  • Deuce's Avatar
15 Jul 2020 08:31
#830725
In case you haven't started yet, try spraying Aircraft Remover on it and let it set. That stuff took off the factory paint on my 900F tank. If sanding, start with about 220 to 400 then go 1000 and 1500. If you don't you'll see all your sanding marks after you paint it.
www.flickr.com/gp/162005819@N03/J055kUZ1a8
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Nessism
  • Nessism's Avatar
15 Jul 2020 17:29
#830763
Aircraft stripper will melt the plastic.:S
  • Nerdy
  • Nerdy's Avatar
15 Jul 2020 17:49
#830766
That doesn't look like sun damage - I think the bike it was on caught fire. :S
If that is the case, the heat may have made the plastic brittle. Be careful not to break it when you're sanding.
Speaking of, agreed that 400 grit would be a good start. Then apply a plastic-specific primer.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Highway Magician
  • Highway Magician's Avatar
16 Jul 2020 21:38
#830850
I would put my Optivisor on and carefully scrape the bulk of it off with a new single-edge razor blade. More than one blade will likely be needed. Then finish sand it.
Motorcycle builder since 1973. Master Tech. Current bike: 1982 GPZ1100B2.
