  • Page:
  • 1
  • 2
pancake compressor and a touch up gun for paint work? 10 May 2020 13:54 #825399
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
  • Thank you received: 48
I'd like to give painting my moto a shot. I actually just spent a lot of money to pay someone else to do it, and wasn't impressed and didn't really like the color I chose in the end. I've painted some in the past with legit equipment, but now I'm in an apartment in the city so I have to downsize. I'm wondering if I can get away with a 6 gallon pancake compressor and a touch up paint gun. Seems like the moto tank and fairings are small enough that I wouldn't need continuous air, just enough to put one coat on at a time. Anybody had success with a similar setup? I did find this reddit post which was encouraging -
www.reddit.com/r/motorcycles/comments/3l...ir_compressor_for_a/
1990 Zephyr zr550 B1
Factory Pro Stage 1 jet kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Last edit: by Zaddict.
pancake compressor and a touch up gun for paint work? 10 May 2020 15:21 #825406
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2672
I don't think there is enough airflow to drive the gun for anything other than small contrast color work. At least the pancake I used to have. When you go to clear the tank you need enough air to fog the tank all over and keep the paint wet or it's orange peel city. If you don't have an air compressor now would be a good time to invest. I have a large compressor which I normally use but I also have a California Air Tools 1.0 HP jobby that I've used in a pinch when painting a bicycle frame. These compressors are awesome; so quiet, and seals up well too. After charging the pressure doesn't drop for more than a week.
The following user(s) said Thank You: Zaddict
pancake compressor and a touch up gun for paint work? 10 May 2020 18:16 #825418
  • oldzed
  • oldzed's Avatar
  • Thank you received: 10
I have a system for painting away from mains power.
I have a scuba diving tank and a regulator with a PCL valve on one of the regulators low pressure ports.
NOTE YOU MUST ONLY CONNECT THE GUN TO A LOW PRESSURE PORT.
Depending on the size of the cylinder you can paint a full motorcycle twice over .
There is no moisture in the air and no oil.
The only thing to be aware of is that the air will be colder than from a compresor.
I run a long hose through warm water or keep the cylinder in a vehicle with the heaters on when its cold outside
My local dive shop fills the bottles for a small fee and I can also use the bottle as an air feed for a mask.
many dive shops have seconhand regulators and bottles for sale
pancake compressor and a touch up gun for paint work? 11 May 2020 00:22 #825436
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
You could use a Preval kit and Spraymax 2K clear.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
pancake compressor and a touch up gun for paint work? 11 May 2020 07:18 #825449
  • Zaddict
Kidkawie wrote: You could use a Preval kit and Spraymax 2K clear.
Oh, interesting. I've used the spraymax 2K clear. Very nice product. Never tried a Preval kit. Why not just spray clear coat with that kit as well?
zx550 cams
K&N Air Filter...
pancake compressor and a touch up gun for paint work? 11 May 2020 07:18 #825450
  • Zaddict
oldzed wrote: I have a system for painting away from mains power.
That's kind of genius
zx550 cams
K&N Air Filter...
pancake compressor and a touch up gun for paint work? 11 May 2020 07:20 #825451
  • Zaddict
Nessism wrote: I also have a California Air Tools 1.0 HP jobby that I've used in a pinch when painting a bicycle frame. These compressors are awesome; so quiet, and seals up well too. After charging the pressure doesn't drop for more than a week.
Does look very nice. I particularly like how quiet it's supposed to be. That may be the winner. Thanks!
zx550 cams
K&N Air Filter...
pancake compressor and a touch up gun for paint work? 11 May 2020 08:13 #825455
  • Zaddict
OK, I think I have a plan. I'll get a low volume paint gun (3-3.5 SCFM) and the California Air Tools 1.0HP compressor. That compressor is small and quiet enough that it won't drive my neighbors crazy. That set up should be fine for base and color coats, since it's not as important that those all go on at once. I can use a Spraymax aerosol 2K clear for the top coat which will avoid the issue Nessim brought up, where I need to keep the clear wet to ensure a smooth finish. Boom!
Thanks all!
zx550 cams
K&N Air Filter...
pancake compressor and a touch up gun for paint work? 11 May 2020 16:28 #825497
  • Nessism
  • Nessism's Avatar
If you find the right gun that compressor should be okay for shooting the clear. I'd do that over Spraymax.
pancake compressor and a touch up gun for paint work? 12 May 2020 07:58 #825532
  • Zaddict
Nessism wrote: If you find the right gun that compressor should be okay for shooting the clear. I'd do that over Spraymax.
What's your hesitation with using the spraymax 2k clear? Quality of the paint? Application issues? (or both or neither?)
sidenote - found these guys who offer a huge selection of premixed House of Kolor paints in aerosol cans, including HOK 2k sealer/primer:
www.66autocolor.com/house-of-kolor-paint-s/151.htm
zx550 cams
K&N Air Filter...
pancake compressor and a touch up gun for paint work? 12 May 2020 10:29 #825545
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
you can get a decent paint job with aerosol cans but it will never be as nice as a job you do with a gun. the advantages of the cans is ease of use and low barrier to entry. the quality of the paint is better before its mixed and re-formulated to work with an aerosol.
pancake compressor and a touch up gun for paint work? 13 May 2020 02:39 #825607
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Spraymax already has the aerosol, 2 cans will do a bike. I used 1 but would have liked another 1/2 can for mine. I used the Preval kit to paint the trunk and door jambs on a Cuda I restored. The tank below is Color Match aerosol and Spraymax. The final finish depends on how good you knock down any peel and polish it.
1975 Z1 900
2004 KX125
  • Page:
  • 1
  • 2
