  • Page:
  • 1
Z250 rims on a 440ltd 05 Mar 2020 16:25 #820362
  • zachsnacks
  • zachsnacks's Avatar Topic Author
  • Thank you received: 1
Hello everyone, I finally got my 440 running, series of unfortunate events, but I figured it out.
Looking to fit a z250 belt drive drum brake rim on a kz440 belt drive drum brake bike. Moving from a 16 rear to a 18 rear.
Cant find part numbers to cross reference if it will fit, can one of you help me out?
Thanks
1983 Kawaski 440 Ltd
I promise I wont make it a cafe racer if you help me out.
The following user(s) said Thank You: deano68
Z250 rims on a 440ltd 06 Mar 2020 06:08 #820392
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
I just took a quick look at the parts cross reference lists at Partzilla for the rear wheel assembly. I checked axle, bearings, spacers, brake parts, drive belt and drive belt pully, and I found not one single part in common with the 250. That suggests to me that some fabrication will be needed to make that swap, maybe quite a bit.
Z250 rims on a 440ltd 06 Mar 2020 06:23 #820396
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
Maybe you've already considered this, but if you're looking to switch to an 18" Rr wheel, you could get a chain drive 440 Rr & do the belt-to-chain conversion. It's supposed to be a direct swap.
The following user(s) said Thank You: zachsnacks
  • Page:
  • 1
