  • Page:
  • 1
Custom Milled Emblems 28 Feb 2020 13:20 #820023
  • Ejedmo5
  • Ejedmo5's Avatar Topic Author
  • Thank you received: 3
Thought I would show these off. Got bored in the UK decided to make a few emblems with some stock that was destined for the scrap yard.
Still finishing up the painting process. But will be for my 1981 kz1000. Bike will be a matte blue so I think the red will look nice
Last edit: by Ejedmo5. Reason: Inserted photos
Custom Milled Emblems 28 Feb 2020 14:28 #820025
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Very nice. Next time you post pics would you mind clicking the Insert or Insert All button before clicking Submit so that the pics will show up in the post?
Last edit: by TexasKZ.
Custom Milled Emblems 28 Feb 2020 14:44 #820029
  • Ejedmo5
TexasKZ wrote: Very nice. Next time you post pics would you mind clicking the Insert or Insert All button before clicking Submit so that the pics will show up in the post?
Thanks hadn’t seen that before, fixed it.
The following user(s) said Thank You: Nessism, TexasKZ
Custom Milled Emblems 28 Feb 2020 14:47 #820031
  • TexasKZ
  • TexasKZ's Avatar
Do you have plans to make any for sale?
Custom Milled Emblems 28 Feb 2020 14:59 #820034
  • Ejedmo5
It’s something I would definitely consider, I don’t have access to a mill stateside but I do when I’m in the UK. If there’s a lot of interest in it. I think we could easily make it happen.
Custom Milled Emblems 29 Feb 2020 07:16 #820056
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Very well done!
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Custom Milled Emblems 29 Feb 2020 12:22 #820068
  • M_a_t_t
  • M_a_t_t's Avatar
  • Thank you received: 41
Are you planning on using these on the tank or side covers? If its for the tank then I'm curious as to how you will get the curve in it (do all tank emblems have the curve or just most?).
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
Custom Milled Emblems 29 Feb 2020 14:05 #820078
  • Ejedmo5
Yeah the long ones will be for the tank, hoping to test fit tomorrow the screws on my tank are stiffer than a .... so trying to get those off without rounding the heads has been difficult. Anyways these are 2mm thick I have been able to give them a nice curve by hand, I plan to exaggerate the curve so the screws hold it all tight against the tank. I laser cut a plastic piece to prevent it from scratching the tank as well as add some more depth to the look.
It’s subtle but there, in the background you can see the piece for the big emblems which will be for the side covers. I do worry about these fitting against the cover I have not tested them yet.
Custom Milled Emblems 04 Mar 2020 06:51 #820265
  • Kawidave
  • Kawidave's Avatar
Very nice work.
Custom Milled Emblems 09 Mar 2020 16:30 #820630
  • Ejedmo5
Been working on the other bike, but I test fit the tank emblems today, need to countersink the holes but they fit. (Obviously this tank still needs painted)
Custom Milled Emblems 10 Mar 2020 09:00 #820666
  • TexasKZ
  • TexasKZ's Avatar
Nice
  • Page:
  • 1
