  • Page:
  • 1
  • 2
Redoing Z1R 26 Nov 2019 16:18 #814616
  • Z1R rider
  • Z1R rider's Avatar Topic Author
  • Thank you received: 5
ayeckley wrote: Lexan is just the GE trade name polycarbonate. Kind of like Teflon is Dow Chemical’s trade name for PTFE.
My terminology might be wrong, but the stuff we use as glass replacement in our drag cars is called Lexan, and is pliable to a degree and drillable without shattering or cracking, unlike the Plexiglass the Z1R windscreen is made of.
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
Redoing Z1R 27 Nov 2019 03:32 #814630
  • ayeckley
  • ayeckley's Avatar
  • Thank you received: 29
Gotcha. I’ve never noticed a difference, but then again I don’t work with either on a regular basis.
1976 KZ900A4 (1105 Project)
1976 KZ900A4 (Stock Project)
1978 KZ1000A2 (Completed Project)
1983 ZX750 A1 aka GPz 750 (Completed Project)
1983 ZX750 A1 (Almost Road-Ready)
1973 CL350K4 (Completed Project)
Redoing Z1R 25 Feb 2020 10:31 #819864
  • Z1R rider
Got a windshield from Red Line Cycle, it is shaped and cut correctly and the color is at the least very close to right. When comparing it to my 42 year old stocker it's darker than were the sun bleached it and a little bit lighter than under the rubber trim at the back. I drilled holes to mount the stock rubber trim again, luckily all went well and they drilled without any problem. I used a standard steel bit in a drill press running at 650 rpm, and light pressure with a wood block under the plastic for support as I drilled.
1978 KZ1000, Z1R
Redoing Z1R 06 Jun 2020 12:20 #827453
  • Z1R rider
First firing in 7 years.
1978 KZ1000, Z1R
Last edit: by Z1R rider.
Redoing Z1R 09 Jun 2020 08:11 #827657
  • Hawaii_Z1R
  • Hawaii_Z1R's Avatar
  • Thank you received: 12
Great! Sounds awesome - love the shop!
1978 Z1R
1976 KZ900
2017 Versys 300X
2021 CT125
The following user(s) said Thank You: Z1R rider
Redoing Z1R 09 Jun 2020 08:40 #827662
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 600
That first start is so satisfying!
Good ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Redoing Z1R 09 Jun 2020 10:02 #827677
  • Z1R rider
Hawaii_Z1R wrote: Great! Sounds awesome - love the shop!
I do like the sound of the stock pipe. - it's kinda my dream garage :) , but it's attached so the wife doesn't always appreciate the smells that find they're way into the house :sick: :whistle:
1978 KZ1000, Z1R
Redoing Z1R 09 Jun 2020 10:15 #827678
  • Z1R rider
slmjim+Z1BEBE wrote: That first start is so satisfying!
I was pumped it started so quickly as you can see at the end of the video, "yeah!" B)
I went through the carbs and "wet benched" them, good thing I did as the overflow tube in one of the bowls had a split in it and would start puking at about 1/3 full in the bowl. It had started doing that just before I parked it, I thought it was a needle and seat not sealing.
1978 KZ1000, Z1R
Redoing Z1R 15 Jul 2020 09:55 #830738
  • Z1R rider
I’m about done with my resto, just a few things left. I picked it up in 1980 as a salvage bike from an insurance liquidator, bike had 62 miles on it. I don’t know if it had been sold and wrecked that quickly or if it was on a demo ride, in any case someone had painted it black with hand painted gold pinstripes before it was totaled. I followed that theme when I repaired it, a few years later I wanted something with more flash hence the black, red, yellow paint. Eventually I resprayed it with the stock color, and this last fall started to restore it.
1978 KZ1000, Z1R
Redoing Z1R 15 Jul 2020 18:57 #830772
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
Your bike looks fantastic. The color match seems to be excellent in the photos. How did you get that color? Any chance you have a code or formula for that color?
My dad's '74 Z1
'00 ZRX1100
Redoing Z1R 15 Jul 2020 19:40 #830774
  • Thank you received: 2829
Beautiful bike! If it could talk I'm sure it would thank you very much! Ed
Last edit: by 650ed.
Redoing Z1R 16 Jul 2020 04:31 #830792
  • Z1R rider
DOHC wrote: Your bike looks fantastic. The color match seems to be excellent in the photos. How did you get that color? Any chance you have a code or formula for that color?
Had a local auto paint mixer-seller (Auto Body Specialists) scan the original color that I exposed under the black paint on the fender. The formula is for "Omni" branded MBC base coat, mixing label says;
Tinting Guide MBC 32377***B
M127..........398.5
M128............57.4
M133............42.9
M117...............6.1
M150..........499.8
this made a quart of base coat
1978 KZ1000, Z1R
  • Page:
  • 1
  • 2
