  • Page:
  • 1
  • 2
No surface prep spray any substitute? 04 Jun 2011 11:16 #455337
  • jjdwoodman
  • jjdwoodman's Avatar
  • Live free, or die.
  • Thank you received: 1
The advice you are getting about solvents for cleaning are directed toward pre paint cleaning, not in between coats.
DO NOT use a solvent such as lacquer thinner, mek, brake cleaner or other except to clean oily residue off the part before you start, and let it dry well before priming.
After your primer dries good you are going to be looking at wet sanding between coats to level the finish. That's where the prep spray you are talking about comes in. For my stuff I just blow the part off good with compressed air from an oilless compressor. If you don't have one then you'll need either some electronic parts blaster (air in a can) or an in between coats wash of some kind. But the solvents mentioned above will lift or melt your finish, so that's a NO NO. If you are diligent you can clean it up with a tack cloth. If you feel more comfortable with a wash cleaning I'd find an automotive paint store.
What ever you use for in between coats, wear a pair of clean gloves as mentioned to avoid leaving oil off your hands.
Good luck
77 650b
81 550 Mostly there
83 ZN1300 Voyager
No surface prep spray any substitute? 04 Jun 2011 13:37 #455377
  • Topper
  • Topper's Avatar Topic Author
  • Thank you received: 133
Thanks for the advice.
Fourth time turned out to be the charm. I went to one more auto parts store in town and finally found one lone can of prep spray. I hope its enough!
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
No surface prep spray any substitute? 04 Jun 2011 16:35 #455403
  • PaintWorkz
  • PaintWorkz's Avatar
  • Thank you received: 68
DoubleDub wrote:
PaintWorkz wrote: Best to find a local Auto Body Supply store. A PPG store would have Wax & Grease Remover for wiping down in between color steps. You would only need to do that to remove fingerprints or tape residue or sanding sludge.
You can spray enamel over lacquer, but spraying lacquer over uncured enamel will cause lifting/wrinkling.
Hope this isn't a hijack - how about Eurethane paints? Is there a standard compatibility issue mixing lacquer or enamel and eurethane?
Thanks!
Urethane is a type of enamel....so it could go over lacquer. Best to do the whole job in urethane or the whole job in lacquer....at least that is what most paint manufacturers will tell you. House of Kolor is the only one that says it is OK to do it all colors in lacquer and then a Urethane final clear, but I don't think they sell lacquer any more.
www.paintworkz.com
84 Gpz900 street
77 KZ 1325 Turbo Dragbike project
79 CBX Pro Stock projects (2)
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
No surface prep spray any substitute? 04 Jun 2011 20:48 #455448
  • DoubleDub
  • DoubleDub's Avatar
  • Visitor
PaintWorkz wrote: Urethane is a type of enamel....so it could go over lacquer. Best to do the whole job in urethane or the whole job in lacquer....at least that is what most paint manufacturers will tell you. House of Kolor is the only one that says it is OK to do it all colors in lacquer and then a Urethane final clear, but I don't think they sell lacquer any more.
Thanks for the info!
No surface prep spray any substitute? 05 Jun 2011 13:40 #455604
  • kawman66
  • kawman66's Avatar
  • Thank you received: 5
not any brake cleaner will work only the zep cleaner!!!!!!!!!!!!!!!!!!!!!
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
No surface prep spray any substitute? 06 Jun 2011 00:17 #455707
  • jjdwoodman
kawman66 wrote: not any brake cleaner will work only the zep cleaner!!!!!!!!!!!!!!!!!!!!!
Please clarify. Do you mean Zep brake cleaner will not harm fresh paint, or do you mean only zep is suitable for pre-paint cleaning?
77 650b
81 550 Mostly there
83 ZN1300 Voyager
No surface prep spray any substitute? 07 Jun 2011 21:32 #456005
  • kawman66
  • kawman66's Avatar
yes the zep brake clean will not harm fresh paint as long as it is dry and i use it as a pre- paint cleaning. the barrel at work says it is brake parts wash.
If your wiping paint in between coats then you should be wet sanding to get proper adhesion.
here is some pics of a ducati i just got done painting
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
Last edit: by kawman66.
No surface prep spray any substitute? 29 Jun 2021 07:55 #850878
  • Jasmin2
  • Jasmin2's Avatar
Yes, I did. The paint cured for several hours and became transparent
No surface prep spray any substitute? 29 Jun 2021 09:25 #850881
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2050
Yes? You did what?
  • Page:
  • 1
  • 2
