Center Stand
14 Jul 2024 14:20 #902107 by tomsbadkz
Center Stand was created by tomsbadkz
    Just kind of curious why someone would cut off center stand bracket so no center stand can be used to put an exhaust on that has to be completely removed just to change the oil.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Bored throttle bodies
14 Jul 2024 14:30 #902109 by Wookie58
Replied by Wookie58 on topic Center Stand
Would it not be easier to use a paddock stand than mess about re-fitting a main stand for this purpose (my brackets are still in place as this is where my lift picks up from)
  • Scirocco
  • Premium Member
14 Jul 2024 14:37 - 14 Jul 2024 14:43 #902110 by Scirocco
Replied by Scirocco on topic Center Stand
Because they can or are not the brightest candle on the birthday cake.
See a lot of stupid repairs, fixes, mods, upgrades, conversions, stupidities of so called wanna be mechanics @ Youtube channel "Just Rolled In"
Last edit: 14 Jul 2024 14:43 by Scirocco.
15 Jul 2024 03:52 #902134 by willemZ900
Replied by willemZ900 on topic Center Stand
I use the centerstand only in wintertime when the Z is sleeping or when i want to change tires. The paddock stand is for oil change or chain cleening/ajustement.  I dont understatement People Who cut of the brackets.
15 Jul 2024 06:01 #902137 by tomsbadkz
Replied by tomsbadkz on topic Center Stand
Yea, i generally use my lift for oil changes and such, but i like having original stand. If id have issue along the road and need wheel off the ground for a broken chain, etc.  Thanks guys. Just wanted to ask others cause the guy i bought the bike from had a shit fit cause i took off the exhaust he had on it. Like i said, couldn't even change the oil without total removal.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
  • slayer61
  • KZR FLAG RELAY CARRIER #62
17 Jul 2024 08:50 #902260 by slayer61
Replied by slayer61 on topic Center Stand
I have a full collection of paddock stands, and I cut off my center stand lugs to clear the exhaust on my Suzuki. I have to drop the exhaust anyway to change the oil. To me, it's no big deal
17 Jul 2024 15:58 #902283 by Cra-z1
Replied by Cra-z1 on topic Center Stand
Then you got the guys who cut off everything to save weight
17 Jul 2024 16:02 #902284 by tomsbadkz
Yes , i'm sure that will make a difference on a six hundred pound motorcycle
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
17 Jul 2024 17:19 - 17 Jul 2024 17:20 #902286 by sf4t7
Replied by sf4t7 on topic Center Stand
My center stand became a shop tool 40 years ago when installing my Kerker (now it's installed only for oil and filter, tire, and chain / sprocket changes).  Didn't notice any performance gains from the slight weight reduction
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 17 Jul 2024 17:20 by sf4t7.
  • Kelly E
  • Never Give Up. Never Surrender
17 Jul 2024 17:31 #902288 by Kelly E
Replied by Kelly E on topic Center Stand
I installed a center stand on my 77' KZ 1000LTD because it didn't come with one but has the mounting brackets. It had the dealer mounted Kerker that was trashed. I replaced it with a stainless steel Delkevik that allows you to use a center stand.
No center stand on a chain driven bike kinda sucks.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
17 Jul 2024 17:37 #902289 by tomsbadkz
Yeah, I kept the brackets on my pro street KZ and can just slide the bolts in and use the centerstand at the house if I need it. Its not designed for long rides. Race gas mix and big block cylinder. Doesnt like hot summer days much.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
18 Jul 2024 01:01 - 18 Jul 2024 01:02 #902292 by Wookie58
I guess it also depends how you use your bike. I can't speak for my KZ (yet) but many other bikes I have ridden had a tendency to "ground" the main stand on left hand bends which can be exciting   I guess this isn't an issue if your bike is set up for straight line performance
PS: real nice GPZ
Last edit: 18 Jul 2024 01:02 by Wookie58.
