  • Page:
  • 1
  • 2
Grab rail 27 Feb 2024 03:48 #895651
  • Andyp62
  • Andyp62's Avatar Topic Author
  • Thank you received: 3
Hi all
I would like to fit a grab rail to my 1978 Z650 B2, does anyone know if one would fit from another bike?, maybe a z900 or 750?
thanks
1978 Z650 B2, US import to the UK
Grab rail 27 Feb 2024 05:48 #895656
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1628
Are your frame grips missing or are you wanting a 1-piece unit that curves around the seat?
1978 KZ650-B2 Fender diagram:
www.partzilla.com/catalog/kawasaki/motor...978/kz650-b2/fenders
Last edit: by martin_csr.
Grab rail 27 Feb 2024 10:41 #895668
  • Andyp62
The frame grips are on but I wanted to fit one that goes round the seat as on the Z900
The following user(s) said Thank You: Injected
Grab rail 27 Feb 2024 17:10 #895683
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 374
Kawasaki did make a unit (part # 32109-1025) like what you are seeking. The part was used in the UK and EU markets at least that is my understanding. I know the 81,82 and 83 F models for the Z650 machines. I do not know of anyone making it now but you may get lucky and find an old one on line.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Andyp62
Last edit: by Street Fighter LTD.
Grab rail 27 Feb 2024 23:41 #895691
  • Andyp62
Thanks for the info I will start looking
Grab rail 29 Feb 2024 05:00 #895738
  • martin_csr
By gd4now: Kawasaki did make a unit (part # 32109-1025) like what you are seeking. ... {parts diagram} ...
Is that parts diagrams from a microfiche? Thanks.
Andyp62: the Jarlef z650 site has some pics. the D grip looks different than the F.  >> jarlef.no/Kawasaki/Series/Z/650/Z650F.htm
Grab rail 29 Feb 2024 07:57 #895743
  • gd4now
  • gd4now's Avatar
Yes the pic came from a on line parts lists for the F2, F3, and F4 Z650s.  z650.surr.fr/parts.html
Here are the part #s that I have found for the grab rails that were stock on 650s  As I understand it the grab rails for the D and E models are different length than the one used on the B, C, and F1 model.
 32109-016 - one on each side
 KZ650-B1 (1977)
 KZ650-B2 (1978)
 KZ650-B2A (1978)
 KZ650-B3 (1979)
 KZ650-C1 (Custom) (1977)
 KZ650-C2 (Custom) (1978)
 KZ650-C3 (Custom) (1979)
 KZ650-F1 (1980)
 32109-1025  one piece both sides and back of seat
 KZ650-F2 (1981)
 KZ650-F3 (1982)
 KZ650-F4 (1983)
 32109-1002 - one on each side
 KZ650-D1 (SR) (1978)
 KZ650-D1A (SR) (1978)
 KZ650-D2 (SR) (1979)
 KZ650-E1 (LTD) (1980)
 32109-1016   one piece both sides and back of seat
 KZ650-H1 (CSR) (1981)
 KZ650-H2 (CSR) (1982)
 KZ650-H3 (CSR) (1983)
 KZ750-H1 (LTD) (1980)
 KZ750-H2 (LTD) (1981)
 KZ750-H3 (LTD) (1982)
 KZ750-H4 (LTD) (1983)
 KZ750-M1 (CSR Twin) (1982)
1977 KZ650 B1
This is my Z
Last edit: by gd4now.
Grab rail 29 Feb 2024 15:18 #895763
  • Andyp62
Thanks , will see what I can find out there
Grab rail 29 Feb 2024 15:19 #895764
  • Andyp62
Great information, thanks for the heads up
Grab rail 01 Mar 2024 14:22 #895794
  • Injected
  • Injected's Avatar
  • Thank you received: 423
You should not have a issue finding one at a breakers in the UK. There seems to be a lot of F models over there.
Grab rail 09 Mar 2024 03:05 #896202
  • Andyp62
That is just what I am looking for thanks
Grab rail 09 Mar 2024 07:48 #896217
  • gd4now
  • gd4now's Avatar
OK not sure why but I feel like I sort of sent you down a rabbit hole.  I asked on the z650 proboards site about the grip for the F model bikes as was told they are like hens teeth, you will not find one.
You did ask if there were other grips from other bikes that might be made to work. I do not know off the top of my head if any other units would work on a 650. I think the issue would be the length/distance between the connections points.
Kawasaki did make another like grip for the 650 H models (these were sold in the US unlike the F2 F3 F4) The part# is 32109-1016. It is my understanding, not saying my understanding is correct, that the connection points are not the same on the B, C and F and is not a direct bolt on. It is also my understanding the the above part will work a 750 twins.
Others here may be able to measure the connection points on the different models to see if any will fit.
Sorry for sending you down the rabbit hole!!!!!
1977 KZ650 B1
This is my Z
  • Page:
  • 1
  • 2
