1977 1000 A1 forks
  • Pattenrd
  • Pattenrd's Avatar Topic Author
1977 1000 A1 forks
04 Sep 2023 09:34
#889011
Restoring a A1 took forks apart to powder coat lowers when i took inner tubes apart to check spring discovered two different types  one with long dampener rod and long spring and one with short rod and spring it looks like 77 had short rod any information would be appreciated ito identify without taking apart large swap meet coming up would like to make it correct
  • hardrockminer
  • hardrockminer's Avatar
Re: 1977 1000 A1 forks
04 Sep 2023 11:00
#889015
Checking Partzilla, it looks like 77 has the same internals as 76 and 78.  Probably 79 and 80 as well.
The following user(s) said Thank You: Pattenrd
  • TexasKZ
  • TexasKZ's Avatar
04 Sep 2023 17:33
#889029
Maybe set up for flat track racing
  • Mikaw
  • Mikaw's Avatar
04 Sep 2023 19:33 - 04 Sep 2023 19:34
#889034
I’ve got a set of ‘77 A1’s on the bench right now, the only difference is in the color of the dampner.  One is silver and the others is gold. Must have been something a PO did. Maybe one was damaged and they replaced it without tearing them apart and never knew they were a miss match.
Last edit: 04 Sep 2023 19:34 by Mikaw.
  • hardrockminer
05 Sep 2023 04:06
#889051
Those look real nice!!
  • Pattenrd
05 Sep 2023 08:58
#889073
No way  guy road on street don't think he knew what he had
  • Pattenrd
05 Sep 2023 09:02
#889074
What is the spring length did you disassemble through botton by removing c clip or just take out of the top you think the 76 tube would work thanks for the help
  • Mikaw
  • Mikaw's Avatar
05 Sep 2023 14:56 - 05 Sep 2023 14:59
#889083
Those look real nice!!m
Fork lowers were vapor honed (blasted). Recently rebuild two set of Z1 forks for Wheelhop at our Zukey Lake get together. Same guy did/does my blasting.
Last edit: 05 Sep 2023 14:59 by Mikaw.
  • Mikaw
  • Mikaw's Avatar
05 Sep 2023 15:05 - 05 Sep 2023 16:02
#889084
the spring can not be removed through the bottom of the upper. The dampener will not come out the bottom. The only way to remove the spring is by removing the cap nut. I’ll measure the item and post for your reference. You can compare
  EDIT
Removed FSM page. Information was incorrect for this post
Last edit: 05 Sep 2023 16:02 by Mikaw.
  • Pattenrd
05 Sep 2023 15:14
#889085
Thats what i thought I'll check clymer manual again  ive done a 78 b2 and a 74 z1and they were both long dampener spring length would help thanks for your information
  • Pattenrd
05 Sep 2023 15:23
#889086
Z1 forks and 77 kz forks are different ive done a couple z1 and a 78 b2 77 has short dampener rod. forks look real pain  real nice going to vapor blast covers guy i got bike from painted whole motor and cases black. Thanks
  • Mikaw
  • Mikaw's Avatar
05 Sep 2023 15:25 - 05 Sep 2023 16:03
#889087
Mikaw  wrote: Mikaw
EDIT, REMOVED INCORRECT INFO
Last edit: 05 Sep 2023 16:03 by Mikaw.
