  • Page:
  • 1
  • 2
KZ400 longer kickstand 26 Apr 2023 23:13 #883809
  • Feanor_twh
  • Feanor_twh's Avatar Topic Author
  • Thank you received: 9
After the suspension mods the bike now leans too much on the kickstand. I'm looking around and I think a kickstand from a KZ440 will be a bit longer, maybe just what I need.
Someone told me that the center stand on this bike is longer, but didn't give me any facts about the kickstand.
Can someone confirm this for me?
(1976) Kawasaki KZ400-D3. All original, but: electronic reg/rec (Oregon Motorcycle Parts), new handlebar controls (w/ PASS/HORN/lights switch, LED dash lights (superbrightleds.com), Dynatek coil (3ohm), MAC mufflers, HEL brake hoses, rubber fork boots, 4.00 rear tyre (Dunlop K70), chromed chainguard
KZ400 longer kickstand 29 Apr 2023 03:50 #883942
  • Feanor_twh
Nobody around here has a KZ440?
Just knowing the length of the kickstand would be enough to compare it to mine.
KZ400 longer kickstand 04 May 2023 18:08 #884246
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
I had the same issue with my kz650 when I installed longer shocks.
I was using a piece of 2x4 under my sidestand.
Someone suggested why not have a welder lengthen the side stand.
Just so happens I bought a second side stand as mine was missing the little leg to assist deploying it:
Had just over 2" cut off one and added to the other:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: Feanor_twh
Last edit: by rstnick.
KZ400 longer kickstand 04 May 2023 18:48 #884248
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 382
Sorry - I have a couple of them. :) Let me get into the shop and measure the 440B and 440LTD kickstands.
I checked Partzilla: they have different part numbers so they might be different sizes. Also rstnick has a good idea.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
KZ400 longer kickstand 08 May 2023 02:08 #884391
  • Feanor_twh
Thanks mate, that's a great idea, a bit of polishing and painting and it will look like the stock kickstand. For the moment I made a fix that will work, although it invalidates the solution you propose:
"Stalin" was useful only to extend the kickstand hehe. Maybe it's really only good for that.
Last edit: by Feanor_twh.
KZ400 longer kickstand 08 May 2023 02:15 #884392
  • Feanor_twh
In fact there is also a model with automatic return based on the clutch lever.
Thanks, I'll wait for your measurement to compare.
KZ400 longer kickstand 08 May 2023 04:16 #884394
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2078
Seems to me that Germany (and Italy???) was the only country to get the automatically retracting side stand, but it was fully mechanical and had no connection to the clutch lever. You may be mistaking the starter lockout switch that prevents the starter from operating unless the clutch is disengaged, for a side stand retractor.
Last edit: by TexasKZ.
KZ400 longer kickstand 08 May 2023 04:27 #884396
  • TexasKZ
  • TexasKZ's Avatar
Here is a discussion about the mechanism on the BMW K100RT. It clearly has an interface with the clutch release mechanism, so I may be remembering incorrectly about the KZ system.
www.k100-forum.com/t1281-1988-k100rt-side-stand-auto-retracts
KZ400 longer kickstand 08 May 2023 12:16 #884417
  • Nerdy
  • Nerdy's Avatar
The US KZ400s had that mechanism as well. I removed it from the '79 because it made moving the bike short distances around the shop a PITA.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
KZ400 longer kickstand 08 May 2023 15:46 #884423
  • TexasKZ
  • TexasKZ's Avatar
Interesting. I had a 400, but it did not have that feature.
KZ400 longer kickstand 09 May 2023 13:08 #884444
  • Nerdy
  • Nerdy's Avatar
Okay, I finally got the measurements:
1980 KZ440B - the kickstand is 9 inches / 23cm from the center of the pivot bolt to the end of the foot
1981 KZ440LTD - 11.5" / 29cm [measured the same way]
I hope that helps! :)
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
KZ400 longer kickstand 09 May 2023 13:39 #884446
  • Nerdy
  • Nerdy's Avatar
There is a post that screws in to the OEM countershaft sprocket that actuates the automatic retractor; if a PO replaced the chain and sprockets at some point, the actuator might have been removed at the same time.
I stored the original sprocket and mechanism in a baggie in case I ever need to re-install the darn thing. :)
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • Page:
  • 1
  • 2
