Spacer PVC
  • gordone
  • gordone's Avatar Topic Author
Spacer PVC
25 Feb 2023 10:06
#880731
I’m looking into install spacers for my front fork.
will these work?
Ø 5mm / 0.196 inch?
webplast.no/shop/roer-og-stenger/pvc-mas...lEAQYAyABEgJiSfD_BwE
Project:
  • Nessism
  • Nessism's Avatar
Re: Spacer PVC
25 Feb 2023 10:08
#880732
A chuck of PCV pipe from the hardware store works perfectly.  You don't need a solid spacer.
  • gordone
Re: Spacer PVC
25 Feb 2023 10:19
#880733
Ahh what is prefer and max size?
Project:
  • Nessism
  • Nessism's Avatar
Re: Spacer PVC
25 Feb 2023 10:30
#880734
Measure the ID of the fork tube, and buy a piece as close to that size, without going larger.
  • gordone
Re: Spacer PVC
25 Feb 2023 10:35
#880735
Will open up the cap on top and measure the inner size, thank you.
Project:
  • martin_csr
  • martin_csr's Avatar
Re: Spacer PVC
25 Feb 2023 12:05 - 25 Feb 2023 12:23
#880737
I'll probably install 25mm O.D. aluminum tubing & whatever I.D. seems appropriate for the fork spring seat & fork cap.
The stock steel spacer on my 1981 KZ650-CSR is 25mm O.D. steel (thin wall).
In the USA 3/4" pvc pipe = 1" O.D. (1" = 25mm), so that could be used as well.
Last edit: 25 Feb 2023 12:23 by martin_csr.
  • Move0ver
  • Move0ver's Avatar
Re: Spacer PVC
25 Feb 2023 12:48
#880740
when I put the racetech springs in my front end I used a piece of PVC as a spacer to get everything dialed in, and then had made a steel spacer when I was happy with the preload.
  • Nessism
  • Nessism's Avatar
Re: Spacer PVC
25 Feb 2023 13:50
#880742
As long as a steel washer is used between the PVC and the spring, there is no need for a steel spacer.
  • riturbo
  • riturbo's Avatar
Re: Spacer PVC
25 Feb 2023 17:21
#880749
Used quarters on my 550
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • gordone
Re: Spacer PVC
25 Feb 2023 23:45
#880757
Like (1/4) inch = 6.35 mm ?
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Re: Spacer PVC
26 Feb 2023 00:24
#880758
He add a stack of quarter dollar coins on top of the stock steel spacer instead off building a longer spacer.....
The following user(s) said Thank You: riturbo, gordone
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Re: Spacer PVC
26 Feb 2023 00:40
#880759
I had mine made in alloy as part of my fork extensions ( they are 75mm long though so I think it would of been asking a lot of PVC)
