Spacer PVC
- gordone
Spacer PVC
25 Feb 2023 10:06
I’m looking into install spacers for my front fork.
will these work?
Ø 5mm / 0.196 inch?
webplast.no/shop/roer-og-stenger/pvc-mas...lEAQYAyABEgJiSfD_BwE
will these work?
Ø 5mm / 0.196 inch?
Project:
Project:
Re: Spacer PVC
25 Feb 2023 10:08
A chuck of PCV pipe from the hardware store works perfectly. You don't need a solid spacer.
- gordone
Re: Spacer PVC
25 Feb 2023 10:19
Ahh what is prefer and max size?
Project:
Project:
Re: Spacer PVC
25 Feb 2023 10:30
Measure the ID of the fork tube, and buy a piece as close to that size, without going larger.
- gordone
Re: Spacer PVC
25 Feb 2023 10:35
Will open up the cap on top and measure the inner size, thank you.
Project:
Project:
Re: Spacer PVC
25 Feb 2023 12:05 - 25 Feb 2023 12:23
I'll probably install 25mm O.D. aluminum tubing & whatever I.D. seems appropriate for the fork spring seat & fork cap.
The stock steel spacer on my 1981 KZ650-CSR is 25mm O.D. steel (thin wall).
In the USA 3/4" pvc pipe = 1" O.D. (1" = 25mm), so that could be used as well.
Last edit: 25 Feb 2023 12:23 by martin_csr.
- Move0ver
Re: Spacer PVC
25 Feb 2023 12:48
when I put the racetech springs in my front end I used a piece of PVC as a spacer to get everything dialed in, and then had made a steel spacer when I was happy with the preload.
Re: Spacer PVC
25 Feb 2023 13:50
As long as a steel washer is used between the PVC and the spring, there is no need for a steel spacer.
- riturbo
Re: Spacer PVC
25 Feb 2023 17:21
Used quarters on my 550
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- gordone
Re: Spacer PVC
25 Feb 2023 23:45
Like (1/4) inch = 6.35 mm ?
Project:
Project:
Re: Spacer PVC
26 Feb 2023 00:24He add a stack of quarter dollar coins on top of the stock steel spacer instead off building a longer spacer.....Used quarters on my 550
The following user(s) said Thank You: riturbo, gordone
Re: Spacer PVC
26 Feb 2023 00:40
I had mine made in alloy as part of my fork extensions ( they are 75mm long though so I think it would of been asking a lot of PVC)
