Brake lines touch front fender
  • gordone
  • gordone's Avatar Topic Author
08 Feb 2023 05:02
#879896
I have a problem with the brake lines touch the front fender when I`m driving....
Any idea to improve/fix these ?
See pictures below:
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Re: Brake lines touch front fender
08 Feb 2023 05:28
#879898
You can turn your brake line connection so the twist tention move it away from the fender.
  • Mikaw
  • Mikaw's Avatar
08 Feb 2023 08:52 - 08 Feb 2023 08:53
#879902
You can swap in different brackets.
Evilbay 313812247582
Last edit: 08 Feb 2023 08:53 by Mikaw.
  • martin_csr
  • martin_csr's Avatar
08 Feb 2023 10:14 - 08 Feb 2023 10:29
#879905
Have you compared your fender guides to other models? maybe compare yours to the KZ750E or H?
Last edit: 08 Feb 2023 10:29 by martin_csr.
  • gordone
08 Feb 2023 13:11
#879914
I cannot twist mine brike lines… should properly bought different back in time…
Project:
  • gordone
08 Feb 2023 13:13
#879915
compare and see if they looks better and purchase preown on ebay?
thank you will try that
Project:
  • gordone
08 Feb 2023 13:13
#879916
So these type make the brake line to come further out?
Project:
  • urankjj
  • urankjj's Avatar
08 Feb 2023 16:56
#879925
Maybe fit a rigid sleeve over the brake line as it passes through the guide to force it away from the fender ?   I had the same problem, but it was because I had lowered the front end causing the lines and cables to bunch up and rub where they normally wouldn't have.
  • gordone
08 Feb 2023 23:48
#879928
Do you have a exmaple for rigid sleeve, picture/link ?
Thank you
Project:
  • martin_csr
09 Feb 2023 05:54 - 09 Feb 2023 05:59
#879930
Another option. Maybe unbolt the caliper, then spin it around? But this may have the opposite effect of forcing the brake lines too far outward. and might stress the brake lines?
Last edit: 09 Feb 2023 05:59 by martin_csr.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
09 Feb 2023 10:27
#879943
Not sure about the USA but in the UK a twisted flexi-pipe is an MOT fail
  • Injected
  • Injected's Avatar
09 Feb 2023 13:18 - 09 Feb 2023 13:22
#879956
plastic spiral brake line shieth
or (split rubber line with zip tie)
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 09 Feb 2023 13:22 by Injected.
