  • Page:
  • 1
  • 2
kz650B2a handgrips 07 Nov 2022 08:43 #876504
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
Does anybody know what they should look like and who is a good supplier? The once I see on ebay go for like $100/pair??
Also, is right grip is a one piece with throttle tube?
R: 46019-038
L: 46075-028
kz650B2a handgrips 07 Nov 2022 10:11 #876508
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 655
Original grip.
Z1e, zpower, anywhere just check their picture against mine for the grip pattern.
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
kz650B2a handgrips 07 Nov 2022 12:06 #876519
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1892
Z1 handgribs
www.fastriders.de/Handgriffe-Gummi-Schwarz_1
KZ650/900/1000 handgribs
www.fastriders.de/Handgriffe-Gummi-Schwarz_2
Edit: Warren is right! Sorry, It was my foult, have switch the links to the corret handgrips now.
The following user(s) said Thank You: Warren3200gt, katit
Last edit: by Scirocco.
kz650B2a handgrips 07 Nov 2022 12:10 #876520
  • Warren3200gt
Disagree re 650 hand grips Scirocco, the picture I posted is from the 650 I bought new in 77 and still own.
The following user(s) said Thank You: katit
kz650B2a handgrips 07 Nov 2022 14:08 #876529
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
The RH grip is sold w the throttle tube as an assembly.  I've seen a RH grip w/o the throttle tube on EB, possibly for a KZ400. I forget & don't remember what it looked like.
Here's the LH grip. has pic. I guess this looks like the original part on a 70s 650. $33 + sh.
www.partzilla.com/product/kawasaki/46075...f4953b0372a1d6388486
And the RH grip assy (unavailable).
www.partzilla.com/product/kawasaki/46019...f4953b0372a1d6388486
Last edit: by martin_csr.
kz650B2a handgrips 15 Nov 2022 17:00 #876870
  • katit
Ordered set from Japan on ebay. Quality look superb. Listed as KZ650. But I think it's wrong throttle one?? There was no detailed pic and I didn't see it's 1-cable.
I will check I may just use my old tube (metal). But who is wrong?
kz650B2a handgrips 15 Nov 2022 18:15 #876871
  • katit
Seller claims difference in 2 cable vs 1 cable is due to "year". Was there "KZ650" which used one cable throttle?
kz650B2a handgrips 15 Nov 2022 20:41 #876873
  • Warren3200gt
Seller is wrong. Both single cable and grip pattern are wrong for z650b.
That looks like a 80"s throttle tube and grip pattern.
82 Z1000j. Single cable.
77 z650b Twin cable.
kz650B2a handgrips 15 Nov 2022 21:43 #876875
  • katit
Is it possible any newer kz650s used those or they all were 2 cable
kz650B2a handgrips 15 Nov 2022 23:24 #876876
  • Warren3200gt
Don't know anything about the later models but it would seem likely those kind of parts would be shared amongst various models of the year.
Check the cmsnl and khi parts diagrams.
kz650B2a handgrips 16 Nov 2022 05:35 #876877
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2050
Partzilla shows the same two-cable part number for the 650B, C, D, &E1, and a plethora of other models.
www.partzilla.com/product/kawasaki/46019...61f02a85415744b8f589
kz650B2a handgrips 16 Nov 2022 05:59 #876878
  • martin_csr
That appears to be part # 46019-1015 & it was used on a number of 81-on KZ models, especially 82-on.
82-83 KZ650-CSRs came w BS32 carburetors & use the -1015 throttle grip shown >> my neighbor had an 82 w the -1015 grip.
My 81 KZ650-CSR has VM24 carburetors w the earlier -038 throttle grip assy.
Models w CV carburetors sometimes only use one throttle cable.
From the 1982 KZ650-H2 CSR diagrams: 46019-1015
www.partzilla.com/product/kawasaki/46019...80fb1f9d449685225d8a
  • Page:
  • 1
  • 2
