  • Page:
  • 1
Bolts and stuff 13 Aug 2022 15:47 #872176
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
This is just "curious" question. What do those numbers mean on bolts? 4, 7 ? Does it mean "original" kawasaki or not?
I "lost" one of the engine bracket bolts, and then I later found it. It was skipped during plating.
But while looking I searched by PN 92001-1578 and couple came up had "7" stamped. None of my bolts on engine have those numbers. Many other bolts throughout have those numbers.
Maybe it has to do with bike made here in US? Just curious..
Last edit: by katit.
Bolts and stuff 13 Aug 2022 16:56 #872177
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
I believe it's the grade of the steel.
Bolts and stuff 13 Aug 2022 17:20 #872180
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2675
No mark, 4, 7, 9, in order of strength and hardness.
Bolts and stuff 13 Aug 2022 19:12 #872189
  • krazee1
  • krazee1's Avatar
  • Thank you received: 197
"Maybe it has to do with bike made here in US? Just curious."
The hardware we assembled bikes with in Lincoln all came from Japan.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
The following user(s) said Thank You: katit
Bolts and stuff 13 Aug 2022 19:19 #872191
  • katit
Ok, so all the bolts for engine mounting don’t have numbers on them. I am sure they are original. When I lookup pn on ebay- they pop up with #7 on them
Bolts and stuff 13 Aug 2022 19:23 #872192
  • Nessism
  • Nessism's Avatar
Compared to SAE rating...
4 = grade 2
7 = grade 5
9 = grade 8
Regarding unmarked bolts, it's a crap shoot.  They could be nice and strong, just not marked.  On the other hand, they could be made of cheese.
Last edit: by Nessism.
Bolts and stuff 13 Aug 2022 19:27 #872193
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Bolts and stuff 14 Aug 2022 05:49 #872207
  • hardrockminer
Many people believe higher grade is better, but not always.  Higher grade bolts will take more stress but they are more prone to fatigue failure and are not used in applications where fatigue is a design criterion.  Lower grade bolts are still very strong but they are also ductile, which makes them more suitable for fatigue or vibration applications.  The designer will put a lot of thought into which bolt to use for the intended use, and may even specify that a bolt only be used once, or maybe a limited number of times.
Bolts and stuff 17 Aug 2022 07:49 #872379
  • katit
Speaking of those engine bolts. I was going through FSM to find proper torques and interestingly - FSM is different from parts fiche on bolt info. Perhaps it was changed during model run?
Basically, I have 4 short bolts in front of engine (2 on top and 2 on bottom) and 2 long bolts on back.
FSM shows 4 long bolts - 2 in front, 2 on back.
  • Page:
  • 1
