76 KZ900 A4 Largest tire to fit rear wire spoke rim?
  • Olbeedo
  • Olbeedo's Avatar Topic Author
26 Jul 2022 13:32
#871065
I would like o keep the wire spoke rims on this build but I am curious how big a tire I can get on the rear stock wire rim with the drum brake. I will extend the swingarm 6 to 8 inches. I got a 150 on my LTD no problem with plenty of room left but this rim looks smaller.
OlBeedo- KZ for Life........................
  • zed1015
  • zed1015's Avatar
Re: 76 KZ900 A4 Largest tire to fit rear wire spoke rim?
26 Jul 2022 14:06
#871067
Don't go bigger than the recommended size.
Tyre wall flex will ruin the handling.
  • 750 R1
  • 750 R1's Avatar
26 Jul 2022 15:36
#871078
+100, not to mention a 6-8 inch longer swingarm....
  • Irish Yobbo
  • Irish Yobbo's Avatar
26 Jul 2022 16:15
#871085
If OP was worried about handling, they wouldn't be putting on the largest tyre they can and extending the swingarm would they ;)
I believe 4.00-18 is the stock size, which is slightly wider than a modern 100/100-18. A 130 should fit, a 140 may fit. A 130/80-18 tyre is probably the best 'safe' tyre size that keeps the close to the original final drive ratio (only about a 4% increase which will keep gearing close to the same).
I personally wouldn't make these mods either (I'd stick to 110, maybe 120), but it's your bike.
1981 KZ750 LTD
  • Nessism
  • Nessism's Avatar
26 Jul 2022 16:56
#871088
Assuming the rim is 2.15 like many other KZ's, I'd limit the width to 120.  Even that size is pushing the acceptable limit by most tire manufacturers standards, but Kawasaki used that size, so you can too.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
26 Jul 2022 20:29
#871098
I agree with the previous posts.  The stock size is roughly 110.  I currently run a 120 and that's as wide as I will go personally.  I have run a 130 and it chewed a slot in my chain guard, and the sidewall was clearly distorted.  But technically it did "work".
The tire manufacturers generally lists a recommended rim and rim width range.
For Avon Roadrider Mk2 (the tires I'm using), the widest they recommend for use on a 2.15" wheels is 110/90-18  (recommended for 2.15-3.00" rim).  The 120/90-18 and 130/80-18 recommend a rim range of 2.5-3.5", which is kind of close to 2.15"?  As I said, I'm running a 120 and it seems ok.
Interestingly, the 120/90-18 lists the actual width as 129mm wide (closer to a 130), and 130/80-18 shows a width of 137mm wide (closer to a 140).  That Avon 130/80-18 is probably the widest tire you could put on a 2.15" rim.
www.avontyres.com/en-us/tyres/roadrider-mkii
For comparison, the Bridgestone BT46 130/80-18 also gives a rim range of 2.5 to 3.5", but the listed tread width is 128mm, about the same width as the Avon 120/90-18.
www.bridgestone.com/products/motorcycle_...oducts/detail/pr176/
My dad's '74 Z1
'00 ZRX1100
  • Irish Yobbo
26 Jul 2022 23:38
#871102
Also worth mentioning - if extra rubber on the ground is what you're after, you won't get it by going for a larger tyre. It sounds counter-intuitive I know, but the rim width isn't changing, so when you go wider, much of that width is being pulled back by the rim pinching the sides in. The tyre may well be wider, but the pointy profile caused by the narrow rim will result in a smaller contact patch.
1981 KZ750 LTD
  • urankjj
  • urankjj's Avatar
27 Jul 2022 03:39
#871108
My 77-kz has a 3.5 inch rim laced to the stock hub with a 150/70-ZR 18 tubed tire. The swing arm is stock. I did have to notch the chain guard for fitment.
  • Olbeedo
27 Jul 2022 06:45
#871112
Would you happen to have pics?
  • Olbeedo
27 Jul 2022 06:47
#871113
I have a 150 on my 78 LTD so I was hoping for something similar on the wire spoke for the 76, I really want to keep the drum brake set up
  • z1kzonly
  • z1kzonly's Avatar
27 Jul 2022 07:46
#871119
Seeing your extending swingarm. Don't go too long! (It's not a BUSA on cycledrag!) You need a wider rim, just for looks? Make it easy and go with a Suzuki GS 1100 and a 3.5 rim. They show up on ebay from Oink or JJ Copper would have one.Unless you can spoke and true it yourself. Try and find a person to lace and true a spoke rim nowadays!I added 4" to a stock swingarm with a 4" x 16" hog rim with a 150 tire. using 3/8" offset with a 630 chain.Then this bike just sold, GS Szuk had a 3.5 with a 5.5 slick. I shimmed it for a stock front sprocket. Tear it apart! Start building stuff! Then it will sit for 12 years like me!     Crusty Old Bastard that I am! I have built a few!
Plus I put a Harley hubbed parts with 530 chain with a 5.5" x 18" with a 180 tire. couldn't find finished pic, that had a 5/8" plate and offset. And a fiberglass Beasly fender. Sold it to a guy who wanted the shocks kept. I wanted struts. But it was his money.
Just do it!
Marty in Buffalo
  • urankjj
  • urankjj's Avatar
27 Jul 2022 08:59 - 27 Jul 2022 12:57
#871123
Back then, (the 80s), I got the Akront rim and spoke kit from Kosman Specialties and had them lace it up also. Never had any problems with clearance or handling.  R.I.P to Sandy Kosman who passed away this year.  Interesting piece on him here. Good luck on your build.   www.dragbike.com/top-fuel-motorcycle-legend-sanford-kosman/
Last edit: 27 Jul 2022 12:57 by urankjj. Reason: Spelling correction
