  • Page:
  • 1
KZ440 sprocket carrier bearing question 18 Jun 2022 08:06 #869011
  • Sdaniels2010
  • Sdaniels2010's Avatar Topic Author
  • Thank you received: 7
The bearing has a retaining ring...wondering if it is removable without destroying it.
1981 KZ440 A2 LTD
KZ440 sprocket carrier bearing question 18 Jun 2022 11:21 #869017
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1591
So,what´s the problem. Remove the retaining ring, heat up the carrier case around the outer bearing shell and some wags with a drift punch on the inner shell do the job.
The following user(s) said Thank You: Sdaniels2010
  • Page:
  • 1
