Is there any part of the pad face that is not contacting the disk? Asked a different way, does the pad extend beyond the outside edge of the disk?
No...you can't see the top of the pads because it's a sliding pin caliper so I had to remove the pads first, place one with the top edge sits at the top of the rotor & mark where the bottom edge comes to. Then it's just a matter of putting them back in the caliper, positioning back to where it's marked & taking measurements on bolt hole spacing. It's a bit easier on opposed piston calipers because you can see the top of the pads without having to remove from the caliper. That's why I wanted to fit an opposed piston caliper...a 6 piston caliper with those wide pads give more braking action & almost all sliding pin designs only have 1 or 2 pistons.
