  • Page:
  • 1
Headstock 14 Jan 2022 22:15 #860533
  • Samminorwich
  • Samminorwich's Avatar Topic Author
  • Thank you received: 1
Hi guys I put taper bearings in my kz1000A headstock wish I hadn't cus the head lamp brackets are now loose the top tree seems to be 4mm higher than std is this right btw I didn't put the lower first washer in either or dust seal
any help for a safe ride
Headstock 15 Jan 2022 04:35 #860536
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 618
There is a small ring that goes on top of the fork ear.  Did you put it in place when you put things back together?
Headstock 15 Jan 2022 06:14 #860541
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 400
Are you 100% sure you pressed in both races all the way into neck? Those bastards are sometimes tough. Especially when knocking old ones out? Leaving a burr or chisel mark. I always make sure to clean with air grinder and a scotch wheel. Plus I freeze the races. And warm the neck with propane torch.
Also as a tangent. years ago. before allballs racing components, there were 2 different #'s later 1000's and early Z1/KZ900? This was on a drag chassis so did not matter. I recall that set being taller? That was over 12 yrs. ago.
Good luck, recheck them race's
Still have a Kaw! 76 KZ900 Pro-Street.
And The Old Girl, Harley 75 FLH Electra Glide,
Headstock 15 Jan 2022 06:32 #860542
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 213
In reference to HRMs reply, this is the ring he is referring to I believe.  Easy to leave it out sometimes.Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Headstock 15 Jan 2022 07:23 #860544
  • Mikaw
  • Mikaw's Avatar
  • Away
  • Thank you received: 952
To add here, so far every suggestion is correct. There are also a rubber collar and another stamped ring that need to be installed for the headlight bracket to be tight. See red circle added to RickHs post.
Headstock 15 Jan 2022 13:36 #860557
  • Samminorwich
That ring didn't come with the bike didn't notice on dismantling
many thanks Samantha
Headstock 15 Jan 2022 13:38 #860558
  • Samminorwich
Thankyou I found out from people on here and Z power that I am missing the top and bottom rings they were not on the original bike
kind regards Samantha
Headstock 15 Jan 2022 13:39 #860559
  • Samminorwich
Spot on I have ordered these parts
Headstock 15 Jan 2022 16:20 #860573
  • spdygon
  • spdygon's Avatar
  • Thank you received: 104
I have done 7 of my z1-kz with new tapered bearing kit and had no issues.
you need rubber o-ring,washer , chrome cup , light ear then a small metal ring on top.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: by spdygon.
Headstock 16 Jan 2022 08:13 #860583
  • Rick H.
  • Rick H.'s Avatar
If those parts were missing on your bike then it is no wonder things are loose.  I didn't see the upper rings in stock at Partzilla, but I wasn't looking real hard either.
Rick H.
Rick H.
Headstock 16 Jan 2022 09:35 #860590
  • spdygon
  • spdygon's Avatar
Everything available either in Z1parts or Z1enterprice.
just ordered all the pieces for my z1 I’m working on
1974 Z1 900 project
Headstock Yesterday 13:05 #860633
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 1542
At least you did not end up like this…….
The following user(s) said Thank You: DOHC, Samminorwich
  • Page:
  • 1
