No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Well I have the drawing done with the measurements kindly donated DOHC and it is just the template. I was wondering if anyone can tell me the function of the highlighted areas, seeing I’m going to be using handlebar brake and clutch are they used for the cowl mounting in any way? Thanks in advance
The three threaded holes on the left side (you circled two) are where the front master cylinder reservoir mounts. The two threaded holes on the right side are for mounting the self-canceling turn signal control box. The curved slot is for the aiming the headlight up-down. The headlight bucket on the Z1R has a little arm that lines up with that slot.
Here are some pictures:
One other thought I had. Are you going to use a Z1R style bracket to mount the gauges? Or are they just going to be mounted to the top clamp? I ask because the hole in your drawing that reaches way out from the fork leg is used to mount the gauge bracket. If you're not using a similar bracket, you may not need that hole. That hole doesn't have anything to do with the fairing mounts.
I can take pictures of my bike if you need to see how anything fits together. I labeled the mount points...
