  • Page:
  • 1
process for removing piston from master cylinder 31 Jul 2021 14:12 #852916
  • Lord Osis
  • Lord Osis's Avatar Topic Author
  • Thank you received: 5
I have a used rear MC for my 82 GPz550 that appears to be working, but it is full of gunk so I thought I would clean it up a bit
I also located a NOS piston and was debating replacing the old one, although if it aint broke, don't fix it is my philosophy with old vehicles
Is there a way other than using compressed air to remove the piston?
I am also wondering I were to use compressed air, what do I do with the bleed holes, just hope the pressure is enough with them open, or try to close them in some way?
process for removing piston from master cylinder 31 Jul 2021 15:53 #852921
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Did you remove the c-shaped wire clip (retainer)?
process for removing piston from master cylinder 01 Aug 2021 07:58 #852943
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
I've never done it but I have heard of others using a grease gun to force a caliper piston out. I've never had a MC piston get stuck.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: Lord Osis
process for removing piston from master cylinder 04 Aug 2021 09:43 #853142
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 265
I've had to use compressed air to get pistons out of calipers. Keep your fingers out of the way.
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
process for removing piston from master cylinder 04 Aug 2021 15:03 #853161
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
Grease gun!  Compressed air contains a lot of energy...enough to hurt someone when the piston comes flying out.  Grease is virtually incompressible so you don't need to worry about flying bombs.
process for removing piston from master cylinder 04 Aug 2021 21:59 #853182
  • cb900f
  • cb900f's Avatar
  • Thank you received: 30
They should pop out on their own once the C-clip is removed.  There may be some crud on the barrel which is preventing the piston from coming out - clean it up as best as you can.  You could try 'cooking' in boiling water for a few minutes to loosen things up.
  • Page:
  • 1
