KZ 305 CSR
  • Southpaw
  • Southpaw's Avatar Topic Author
  • Away
KZ 305 CSR
19 Jul 2021 06:38
#852010
Hello All,
This is a bit of a long shot but does anyone know off the top of there head the dimension of the fork spring in a KZ 305 front fork?
  • martin_csr
  • martin_csr's Avatar
Re: KZ 305 CSR
19 Jul 2021 10:31 - 19 Jul 2021 10:31
#852030
There's a 250/305 FSM pdf available on the internet (green cover), but the diameter won't be listed if you need that.
The Fork Spring Free Length chart is on page 152. Standard = 452mm. Service Limit = 442mm.
There's also a fork oil chart on the same page. 150cc. 440mm from the top of the inner fork tube.
note:  as per the instructions, check the fork oil level w the springs removed.
Page 112 says to install the fork springs w the smaller diameter end facing down, so that end goes in first.
Last edit: 19 Jul 2021 10:31 by martin_csr.
The following user(s) said Thank You: Southpaw
  • Southpaw
  • Away
Re: KZ 305 CSR
21 Jul 2021 06:01
#852189
 my bad,I meant the diameter of the spring.....but thank you  for that info it will be helpful
  • ghostdive
  • ghostdive's Avatar
Re: KZ 305 CSR
21 Jul 2021 11:44 - 21 Jul 2021 12:14
#852204
Looks like 22mm OD.
www.dotheton.com/index.php?threads/progr...ngs-for-kz400.65674/
Edit for clarity: 305 shares some fork parts with the 440, so springs should be same OD, different stiffness.
2001 ZX-6R
Last edit: 21 Jul 2021 12:14 by ghostdive.
