  • Page:
  • 1
79 KZ650C Rear Master Cylinder 13 Apr 2021 13:40 #846642
  • Stefk88
  • Stefk88's Avatar Topic Author
  • Thank you received: 0
Hey everybody,
My KZ650C rear master cylinder is leaking. I had it bored and sleeved but I cannot find a piston or a cup that goes on the piston to get it to stop leaking. At this point I'd buy an aftermarket master cylinder, but they're all made in China and the reviews say they suck. Any suggestions?
79 KZ650C Rear Master Cylinder 13 Apr 2021 16:24 #846647
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1892
Some pics of your the rear MC would help to get a replacement MC.
79 KZ650C Rear Master Cylinder 13 Apr 2021 17:48 #846650
  • rstnick
  • rstnick's Avatar
  • Thank you received: 372
This thread may be of some help:
KZ650C Rear Master Cylinder Rebuild Parts - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
after you advised of this i went and bought one, it is the right diameter but length is shorter i dont know if this is a problem or not. i also picked up a 14mm front master cylinder for cheap and the seal is as far as i can tell the same size, the pic shows the 14mm front kawasaki seal on the left, the original seal on the piston (which to me looks in good nick) and the CBX on the right, as you see the CBX is shorter. I have cleaned the piston up more since the photo and it now looks fine, so i hope when i finally come to refit one of seals does the job, or even better they all will work.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: by rstnick.
79 KZ650C Rear Master Cylinder 14 Apr 2021 02:58 #846660
  • Mc Tavish
  • Mc Tavish's Avatar
  • Thank you received: 35
Nice of the company you used to bore and sleeve the M/C to dimensions that parts are no longer available!
1978 z650C
  • Page:
  • 1
