  • Page:
  • 1
Front fender Q 13 Apr 2021 01:29 #846613
  • Ojisan rider
  • Ojisan rider's Avatar Topic Author
  • Thank you received: 63
Simple question. Does 18 inch wheel fender, such as GPz, fit on top of 19 inch wheel? I know the contour not going to match but will it physically fit?
Reason is that I may fit 18inch later down the line. And my original front fender is far from nice. Problem is the brackets that hold the fender to the fork. It's in really bad shape. It will fit on the fork, but does not look good at all. Been looking for the fenders on evilbay, but most of them are bent, just like mine.
Anybody have any experience on this?
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
Front fender Q 13 Apr 2021 06:40 #846626
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 265
I put a 17" fender on an 18" wheel on another project recently. I had to shim the fender up slightly. When I put an 18" wheel under a 19" fender recently, it looked kinda odd, but it's my Mrs' bike & she likes it...
Sorry, I got nothing definite for you.
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
Front fender Q 13 Apr 2021 18:12 #846652
  • rstnick
  • rstnick's Avatar
  • Thank you received: 374
I find the mounting holes are usually in a different spot, and sometimes need to drilled.
I've got a stock 19" front fender on in this picture, with an 18" front wheel:
And here with a GPz750 front fender, 18" wheel.
Fender is wider and needs to be squeezed to fit, also new mounting holes drilled to lower it:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Front fender Q 14 Apr 2021 01:34 #846659
  • Ojisan rider
Thanks for the pic and advice guys.
Guess I'll try and find out. At worst, I can either drill new hole or make some kind of bracket to raise up just a little.
  • Page:
  • 1
