  • Page:
  • 1
  • 2
KZ400 fuel tank cap identification 18 Jan 2021 03:05 #841913
  • fricks
  • fricks's Avatar Topic Author
  • Thank you received: 0
Thank you very much!! If I end up finding something similar I will post a link here so others can find a possible replacement too :)
KZ400 fuel tank cap identification 19 Jan 2021 04:12 #841992
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2076
The distance between the seal and the top of the locking tabs might also be important.
KZ400 fuel tank cap identification 19 Jan 2021 08:43 #842008
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1625
By Nerdy: Right, so I was able to find the key *and* the calipers to take some measurements, so here we go.
overall diameter = 71mm
the black O-ring and the metal bit under it = 55mm
the round piece that goes into the tank - the outcropping at the 12:00 position = 34.5mm (C)
the round piece that goes into the tank + the outcropping = 38mm (D)
the two locking pieces when they're out = 41.5mm (E)
the central piece stamped 'Made in Japan' = 26mm (F) ...
Thanks for the measurements. Does this pic look right?
The following user(s) said Thank You: Nerdy, fricks
Last edit: by martin_csr.
KZ400 fuel tank cap identification 19 Jan 2021 14:52 #842037
  • Nerdy
  • Nerdy's Avatar
  • Away
  • Thank you received: 381
martin_csr wrote: Thanks for the measurements. Does this pic look right?
It certainly does - thank you! You beat me to it. :)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: martin_csr
KZ400 fuel tank cap identification 19 Jan 2021 14:53 #842038
  • Nerdy
  • Nerdy's Avatar
  • Away
TexasKZ wrote: The distance between the seal and the top of the locking tabs might also be important.
That's a good point. I will grab that measurement when I have a chance.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: fricks
KZ400 fuel tank cap identification 08 Feb 2021 12:37 #843180
  • fricks
Hey Nerdy, just checking in to see if you've had an opportunity to measure the distance between seal and locking tabs? Thank you
  • Page:
  • 1
  • 2
