Z1KZP swing arm swap 28 Sep 2020 14:13 #835796
  • SWest
  • SWest's Avatar Topic Author
  • Moderator
  • Thank you received: 2080
Gotta get rid of this bolt.
Opinions expressed by me do not reflect those of the the staff or members
Z1KZP swing arm swap 29 Sep 2020 07:03 #835841
  • SWest
  • Moderator
Now I can move on. B)
Z1KZP swing arm swap 29 Sep 2020 07:24 #835843
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 818
Great job, your luck you still have riding weather. Getting very hit and miss here in Michigan. I was disappointed I wasted one of maybe a handful of riding days Sunday when I drove to get the engine. But that turned into joy when I tore down it down.
Get that machine out and ride it like you stole it.
Z1KZP swing arm swap 29 Sep 2020 07:54 #835846
  • SWest
  • Moderator
Yeah the good riding weather is coming soon. Down here summer we're shut ins and most of fall/spring we get to RIDE. :woohoo:
Too bad the Slow Birds have to come down here to screw it up.
You scored on that engine. Those look like the early Wiseco K1015 pistons. They don't make them anymore but the new rings will fit.
I have three good ones in case you need one. Nothing wrong with the old style. B)
Z1KZP swing arm swap 29 Sep 2020 08:29 #835850
  • Mikaw
  • Mikaw's Avatar
Thanks Steve, when I get home later today I’ll post pictures of the pistons. I noticed material missing above the wrist pin bore. If you’d look for me and let me know if they are good or junk. It’s missing material above the wrist pin bore and the lower oil ring. Not sure how that would happen everything was in its place.
Z1KZP swing arm swap 01 Oct 2020 10:39 #835974
  • SWest
  • Moderator
The KZP swing arm is working great. Looks stock too. B) Now I can RIDE THE PISS OUT OF IT even more. :woohoo:
Z1KZP swing arm swap 08 Oct 2020 14:56 #836418
  • SWest
  • Moderator
I'll have to extend the fender. :dry:
Z1KZP swing arm swap 09 Oct 2020 19:38 #836505
  • SWest
  • Moderator
Still aligning the sprocket.
Z1KZP swing arm swap 10 Oct 2020 08:30 #836537
  • SWest
  • Moderator
Decided to dive into it. 2" may be too far. I could drill holes at 1" over and 2" to compare. I'll do that today. B)
Z1KZP swing arm swap 10 Oct 2020 18:06 #836585
  • SWest
  • Moderator
Works great. B)
Z1KZP swing arm swap 11 Oct 2020 06:10 #836605
  • SWest
  • Moderator
Finishing it up.
Z1KZP swing arm swap 11 Oct 2020 16:16 #836659
  • SWest
  • Moderator
It wasn't so easy' :dry:
