Clocks- KZ650SR 1979
  • Evobobber
  • Evobobber's Avatar Topic Author
13 Jul 2020 08:53
#830551
Hi, I am after some advice.
My clocks (speedo) are pretty messy under the glass and I just want to remove the glass, clean up the clocks, then reseal the glass back on.
Any ideas? Thanks
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Clocks- KZ650SR 1979
13 Jul 2020 10:20
#830565
Yes you can by bent back the stainless ring that hold the upper and lower speedo body together with some Patience.
The main problem is to get the ring pressed without dents or scratches.
  • Evobobber
13 Jul 2020 11:37
#830571
Hi, i'll have a go.
Thanks
  • M_a_t_t
  • M_a_t_t's Avatar
13 Jul 2020 12:25
#830573
Do you have any details on how you built that Scirocco? Do you use both halves at once or one to start the fold and the other to finish? It looks like they are at 2 different angles. What is the gauge holder made of, delrin?
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
13 Jul 2020 14:06
#830585
Scirocco wrote: Yes you can by bent back the stainless ring that hold the upper and lower speedo body together with some Patience.
Very nice!!! Ed
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
13 Jul 2020 15:31
#830596
This is a really simple tool made of left over parts, The outer bearing races have to be need a profil grind radius to do a proper re-bent.
Every plasitic, delrin, bacelit, or wooden shaped holder did the Job.
