  • Page:
  • 1
  • 2
1984 GPZ550 rear brake stuck 18 Jun 2020 11:58 #828392
  • dpivas7
  • dpivas7's Avatar Topic Author
  • Thank you received: 8
The rear brake on this 1984 GPz550 I am working on is stuck. when you press on the brake lever, the lever doesn't return, even though the spring is still attached to the mechanism. The reservoir is filled with fluid to the correct level.
Does it need a simple brake bleed or is there something wrong with the caliper?
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
1984 GPZ550 rear brake stuck 18 Jun 2020 12:36 #828398
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Looks more like an rear MC and caliper clean and rebuild Job.
1984 GPZ550 rear brake stuck 18 Jun 2020 13:27 #828402
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Could be the brake lever pivot. It is one of those oft neglected maintenance items. Water and dirt can build up, causing rust on the pivot shaft.
1984 GPZ550 rear brake stuck 18 Jun 2020 13:41 #828404
  • dpivas7
The brake stays locked, even if I pull the lever up
1984 GPZ550 rear brake stuck 18 Jun 2020 14:09 #828406
  • TexasKZ
  • TexasKZ's Avatar
Then it seems a full hydraulic rebuild is in order, though I would still pull the lever off to clean and grease the pivot. Be sure to carefully clean the seal groves in the caliper.
The following user(s) said Thank You: dpivas7
Last edit: by TexasKZ.
1984 GPZ550 rear brake stuck 18 Jun 2020 14:43 #828411
  • dpivas7
Ahh okay! Would it be sufficient to buy a caliper rebuild kit?
1984 GPZ550 rear brake stuck 18 Jun 2020 15:48 #828416
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
This just happened to me on my XS650. You'll need to pull the MC and rebuild it. I would suggest honing as well since the piston is probably seized in the bore.. Try that first and then, if needed, rebuild the caliper.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
1984 GPZ550 rear brake stuck 18 Jun 2020 16:01 #828417
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2674
Motorcycle master cylinders should not be honed. Pull it apart and inspect for pitting in the aluminum. If it's okay install an OEM piston kit and replace the brake line. Same goes for the caliper, only instead of worrying about the bore look at the pistons.
1984 GPZ550 rear brake stuck 19 Jun 2020 12:52 #828476
  • ned37
  • ned37's Avatar
  • Thank you received: 11
sounds like the small return bleed hole in the mc is plugged, keeping the pressurized fluid from returning from the caliper
'83 GPZ1100, '97 Triumph Trophy 1200, '08 Husky TE610
Verde Valley, AZ
1984 GPZ550 rear brake stuck 28 Jun 2020 12:11 #829216
  • dpivas7
I don't see a bleed hole anywhere.
1984 GPZ550 rear brake stuck 28 Jun 2020 14:32 #829226
  • dpivas7
Nessism wrote: Motorcycle master cylinders should not be honed. Pull it apart and inspect for pitting in the aluminum. If it's okay install an OEM piston kit and replace the brake line. Same goes for the caliper, only instead of worrying about the bore look at the pistons.
I can't find any rebuild kits for a 1984 GPz550. Would a 1982-1983 rebuild kit work? The manual says "The rear master cylinder on ZX550-A1 and A2 models has changed slightly from other models" so I don't know if a 1983 would work.
Also can't find any complete rear master cylinders for less than $300
1984 GPZ550 rear brake stuck 28 Jun 2020 15:18 #829242
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1854
This is the tiny hole that allows pressure to be released and allows the caliper to back off a smidge and not drag
  • Page:
  • 1
  • 2
