Update .. I read on here somewhere that the swing arm pivot bolt could be used as the axle if bushings were made for the swing arm,, or atleast that is the way I took it .. it turns out that the pivot bolt is long enough and uses the same nut as the axle But the center is smaller in size than the axle .. so this means you have to change the wheel bearings then drill out all your spacers , Caliper bracket to the larger 20mm .. I found whell bearings at my local bike shop at around 10.00 each ..
I think baldy110 did this, or something like this, maybe pm him
Scott
07 MDP Rookie of the Year
