  • Page:
  • 1
  • 2
Belt Conversion 02 Feb 2006 10:48 #21132
  • The Dude
  • The Dude's Avatar Topic Author
  • Thank you received: 0
I finished my chain to belt conversion. Take a look.
www.armbell.com/forum/viewtopic.php?t=1685&mforum=kz400
Belt Conversion 02 Feb 2006 19:33 #21227
  • storysunfolding
  • storysunfolding's Avatar
Did that block you putting the second shock back on or did you just not get to that yet?
Belt Conversion 02 Feb 2006 19:46 #21228
  • The Dude
Yeah, that was for the sake of the picture. Everything fits back as it should.
Belt Conversion 03 Feb 2006 05:04 #21253
  • dog pound
  • dog pound's Avatar
That looks good, But what about ratio, Sprocket ratio is based on front to rear, How did you size for belt drive.
Cheers Dan
Belt Conversion 03 Feb 2006 06:36 #21272
  • GargantuChet
  • GargantuChet's Avatar
  • Thank you received: 1
Nice job! Back when you were doing research, it seemed like the information was a little sparse. It's good to see that it didn't hold you back!
Belt Conversion 03 Feb 2006 11:38 #21304
  • The Dude
Yeah, there was really no information to be found except that it was supposedly possible. I was at the local salvage yard alot. The ratio's haven't changed that much but there is a change.
The chain was front 15 rear 45 so the ratio is 3
The Belt is front 22 rear 60 here it's 2.72
I've never even thought about what that would do to the ride. So. what did I do did I gain accel or top end.
Belt Conversion 03 Feb 2006 14:14 #21327
  • steell
  • steell's Avatar
  • Thank you received: 207
If you went from a 3:1 to a 2.72:1 you lost accelleration and gained top end (if the motor has enough power to pull it) or at least reduced your rpm at the same speed.
Belt Conversion 03 Feb 2006 15:29 #21333
  • The Dude
Oh, is there any doubt.. come on this thing has got the power. haha
Belt Conversion 25 Apr 2006 11:51 #42542
  • elcid
  • elcid's Avatar
did that front belt pully just bolt on? Are these from a KZ440? I have a KZ650 with a 44 or 45 tooth rear sprocket so it may be the same ratio as your setup before the belt conversion. So what pulley size should I look for to keep the stock gearing (ratio of 3?) This is very encouraging!
Post edited by: elcid, at: 2006/04/26 02:56
Belt Conversion 25 Apr 2006 22:57 #42724
  • smb_racing
  • smb_racing's Avatar
All in the interest of fuel savings I'm sure :laugh:
Belt Conversion 26 Apr 2006 09:22 #42821
  • The Dude
As an update I've put almost 400 miles on the bike since I did everything. No problems so far, most of the riding has been 1 up on country roads. So it hasn't been babied. Everything is still as it should be. Go for it!!!
Belt Conversion 26 Apr 2006 11:22 #42853
  • elcid
  • elcid's Avatar
hey Dude:
did that front belt pully just bolt on? I have a KZ650 with a 44 or 45 tooth rear sprocket so it may be the same ratio as your setup before the belt conversion. So what pulley size should I look for to keep the stock gearing?
  • Page:
  • 1
  • 2
