  • Page:
  • 1
  • 2
Help Identify Mystery Parts? 31 Jan 2006 16:27 #20780
  • skippr76KZ
  • skippr76KZ's Avatar Topic Author
  • Thank you received: 1
:blink: It was bound to happen. Things I took off the old KZ900LTD last year, all of a sudden don't look to familiar to me when it's time to replace or put them back on. Can anybody help me identify these rubber plug type things with a metal sleeve insert? Pretty sure it's not turn signal parts (no diamond shape) but I can't be for sure. In the meantime I'll continue to peruse the parts diagram. These things look pretty worn. Thanks.
1976 KZ900LTD Fully Restored
2000 Vulcan FI Classic
1998 Ducati ST2, Gone
Help Identify Mystery Parts? 31 Jan 2006 16:34 #20784
  • bob_z1
  • bob_z1's Avatar
is there a hole thru them? look like the rear exhaust hanger bushings.....
Help Identify Mystery Parts? 31 Jan 2006 16:53 #20788
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
  • Thank you received: 103
I'm a thinking that they are the rubber pieces that holds the back cowl on. Two on top and two underneith.Roy
Post edited by: roy-b-boy-b, at: 2006/01/31 19:53
Help Identify Mystery Parts? 31 Jan 2006 18:01 #20806
  • 77KZ650
  • 77KZ650's Avatar
  • Thank you received: 7
I have no idea, but this might help the pros out there, try putting a ruler beside them and take the pic again. hope this might help, good luck.
Scott
07 MDP Rookie of the Year
Help Identify Mystery Parts? 31 Jan 2006 18:37 #20810
  • skippr76KZ
I thought too late to put the ruler next to them. I've re-done the photo. The ruler is 6 inches across. I'm thinking the back cowl thing sounds like it might be it. I'll check the parts diagram.
Help Identify Mystery Parts? 31 Jan 2006 18:53 #20813
  • BSKZ650
  • BSKZ650's Avatar
  • Thank you received: 14
I am not sure but they kind fo look like rear fender mount rubbers, missing the tops and bolts
77 ltd1000, current rider
76 kz900, just waiting
Help Identify Mystery Parts? 31 Jan 2006 19:34 #20821
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Thank you received: 181
Exhaust mount dampers from the rear lower mount point - 1 from either side of the mount point on each side of the frame.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Help Identify Mystery Parts? 01 Feb 2006 02:11 #20858
  • roy-b-boy-b
I haven't seen one of those in years! Roy
Help Identify Mystery Parts? 01 Feb 2006 05:58 #20874
  • skippr76KZ
Thank you Jeff! Next question might be, do they look useable in that role. Not sure these things are that readily available. Thanks for the help guys.
Help Identify Mystery Parts? 01 Feb 2006 06:14 #20879
  • wireman
  • wireman's Avatar
  • Visitor
i wonder if Z1 sells them,check wesite:whistle:
Help Identify Mystery Parts? 01 Feb 2006 10:55 #20916
  • roy-b-boy-b
If you see the price of new one you will see thos used one in a diffrent light. Roy :ohmy:
Help Identify Mystery Parts? 01 Feb 2006 13:32 #20944
  • skippr76KZ
Good observation, Roy-b-boy-b. Some soap and water, a tooth brush, metal brush and some aerospace 303 protectant may be in order. Didn't see it on Z1's site wireman - but I'll double check. I about have the kz900 section memorized with all the visits looking for stuff I'm going to have to replace. :pinch:
skipsteiger.home.mchsi.com/before/
  • Page:
  • 1
  • 2
