Clip-on Handlebar help
  • dreamsofaz1r
  • Topic Author
11 Aug 2007 17:52 #163264 by dreamsofaz1r
Clip-on Handlebar help was created by dreamsofaz1r
Looking for info, as well as the right size for a set of clip ons for a kz 650. Added a 750 LTD front set of air suspension forks and to get the right ride angle they just BEG to have the clip ons added to the top of the tubes with as far as they stick out. Will be removing the reguler mounts also and adding small hugging lights to go with the removed rear fender and cats eye rear light, 16 rear tire replacing the 18 incher and it being lowered with shorty shocks.
ohhh, sorry, to get back on track, anyone know the size of the tubes(I beleive it is 36MM) and how much legnth I need on the clip ons to get the handbar pieces on and a place to find them?
Thanks a ton guys.
11 Aug 2007 19:23 #163283 by rstnick
Replied by rstnick on topic Clip-on Handlebar help
This thread has some discussion on it:
clip ons .
Post edited by: rstnick, at: 2007/08/11 22:23
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
13 Aug 2007 06:06 #163504 by galaxian
Replied by galaxian on topic Clip-on Handlebar help
The OD on the forks is 36mm so that is the size you need. To figure out the lenght of the clipon that you may need, just measure the straight area of your stock bar.
ebay: search 36mm clipons
A friend of mine has these they are really nice and price is pretty good.
cgi.ebay.com/ebaymotors/kz-h2-z1-kx-kh-z...QQrdZ1QQcmdZViewItem
Post edited by: galaxian, at: 2007/08/13 09:07
1977 KZ1000A1, 1979 KZ650 C3
13 Aug 2007 08:37 #163526 by loudhvx
Replied by loudhvx on topic Clip-on Handlebar help
The problem with aluminum-clamp clipons is that on some models, the brake master-cylinder hugs the bar with almost no clearance. There is interference with the aluminum clamp.
I use welded steel clipons from Airtech.
www.airtech-streamlining.com/miscpages/handlebars.html
They are also the least expensive ones I found. I use the 36mm "clip 1". Sand down some of the powder coatingon the inside to make it slide on easier.
14 Aug 2007 08:07 #163788 by Jornum1
Replied by Jornum1 on topic Clip-on Handlebar help
I have the same set galaxian is talking about. They are really nice, and well constructed. I have had no clearance issues with my '81 750.
If you want the height of the clip-on area let me know I will measure it for you.
Post edited by: Jornum1, at: 2007/08/14 11:12
