Need some spark plug help with my kz440
- nickmckay
24 Jul 2024 16:07 - 24 Jul 2024 16:08 #902514
by nickmckay
Need some spark plug help with my kz440 was created by nickmckay
So I’ve pulled the spark plugs on my kz440 and this is my first time changing them. I had bought some ngk br8es spark plugs but come to find out they don’t fit in the jacket end. Does anyone know what spark plug I should use that has this skinnier end?
Last edit: 24 Jul 2024 16:08 by nickmckay.
- Thank you received: 2216
24 Jul 2024 16:19 #902515
by TexasKZ
Replied by TexasKZ on topic Need some spark plug help with my kz440
Just screw the top off.
- Thank you received: 2053
24 Jul 2024 16:21 - 24 Jul 2024 16:39 #902516
by Scirocco
Replied by Scirocco on topic Need some spark plug help with my kz440
You have only to un-screw the top spark plug nippel connector!!!
You have to use the B8ES spark plugs with no 5k Ohm resistance!
Don´t use 5k ohm resistance spark plugs and spark plug connector together!!!
Only 5k ohm resistance spark plug or spark plug connector!!!
Or non resistance spark plug or spark plug connector!!!
Last edit: 24 Jul 2024 16:39 by Scirocco.
- Thank you received: 2806
24 Jul 2024 17:03 #902518
by Nessism
Replied by Nessism on topic Need some spark plug help with my kz440
R means resistor. The plug cap already has a resistor, so you don't want to use a resistor plug.
Regarding removing the top, some plug ends are removable, and others are not.
- ckahleer
- Thank you received: 143
24 Jul 2024 20:39 #902522
by ckahleer
94 KE100
81 CM200t
82 KZ305
85 VF1100c
Replied by ckahleer on topic Need some spark plug help with my kz440
NAPA sells b8es. The new NGK p/n is 2411.
94 KE100
81 CM200t
82 KZ305
85 VF1100c
