- Thank you received: 271
Kawasaki Z1/Z2 Left Hand Switchblock
- asphalt900
17 Jul 2024 11:14 #902265
by asphalt900
Kawasaki Z1/Z2 Left Hand Switchblock was created by asphalt900
Gotta reach-out for You European/Domestic market Fellas for this one. I was "told" that the OEM Left hand handlebar switch had a spring detent in the Pa position for the Euro/Japanese market. I've done my share of these but have never ran across a version that when the knob is pushed all the way-up engages the passing feature. Obviously has to be a different "stop" bracket of which is not shown but the US versions all had the same. Triples and Z1 share the same upper LH switch locking upper casting. Any input or experience with this? Thanks a bunch, Clay
- asphalt900
17 Jul 2024 11:17 #902266
by asphalt900
Replied by asphalt900 on topic Kawasaki Z1/Z2 Left Hand Switchblock
- Cra-z1
- Thank you received: 122
17 Jul 2024 15:52 #902282
by Cra-z1
Replied by Cra-z1 on topic Kawasaki Z1/Z2 Left Hand Switchblock
Im working on a 75 Z1 with a broken tab for the high/low beam. If you happen to have the internal switch I may one interested in one. I need to pull my switch bodies down as I may have one hiding in there.
- asphalt900
18 Jul 2024 04:55 #902295
by asphalt900
Yes CraZ1, i have plenty of them. Your switch should be black in color. Is your knob still decent?
- Thank you received: 2281
18 Jul 2024 05:09 #902297
by Wookie58
Replied by Wookie58 on topic Kawasaki Z1/Z2 Left Hand Switchblock
Not sure that's a question to ask in publicYes CraZ1, i have plenty of them. Your switch should be black in color. Is your knob still decent?
The following user(s) said Thank You: asphalt900, slayer61, Moose1800
- asphalt900
18 Jul 2024 05:22 #902300
by asphalt900
Ha ha, should of caught that before submitting!!
- asphalt900
23 Jul 2024 02:34 #902467
by asphalt900
The following user(s) said Thank You: slmjim+Z1BEBE
- slmjim+Z1BEBE
- Thank you received: 732
23 Jul 2024 04:59 #902468
by slmjim+Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Replied by slmjim+Z1BEBE on topic Kawasaki Z1/Z2 Left Hand Switchblock
Are the arrangement of the contacts different to enable momentary at the 'Pa' position? We've never seen one either.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- asphalt900
23 Jul 2024 10:07 #902473
by asphalt900
Jim, also sent to Your phone. But for the masses, some relevant crap. Pictures denote the Kawasaki Triples, typical Z1 then the Euro version plate wiring. ALL the plates are the same, just the soldering of wires that makes the difference for the headlight. Note the US version never utilized the spare two collets on the breadboard, the UK did, An additional "Brown" sheathed wire was attached and the RED/Black wire was bridged for the contacts. Note alo the triples also used the exact same plate but switched the Red/Black and Red/Yellow tracer wires around. Also the triples used a smaller wire and used a Yellow connector or red on the RH switchblock.
- asphalt900
27 Jul 2024 07:51 #902595
by asphalt900
Here's some stuff for You cra-Z1. I believe this will be what you're looking for and some additional. Wookie, keep you're mind out of the gutter I'm still calling it a Knob. My Knob is new and unfettered. They are all shiny clean and ribbed for pleasure of quick activation. Also if anyone hasn't figured this out. A Switch from a Triple can refresh your restoration of these RH switchblocks for the Z1, 72-75. Just have to re-use the 2 contact back plate, triple only had one and the back section doesn't fit anyway.
The following user(s) said Thank You: SWest, Wookie58
