- Thank you received: 7
GPZ1100b1 idle switch and throttle valve switch
- ajh
03 Jul 2024 04:33 #901685
by ajh
1981 GPZ1100b1, 1980 CB750Fa, 1981 RD350LC, 1980 DT175mx, 1982 GS550ez
GPZ1100b1 idle switch and throttle valve switch was created by ajh
Hi B1FI experts
Just wanted to validate Im right in thinking my idle switch is no good, I've removed it and cleaned connections, testing it I have no continuity betwwen the body/ground and the terminal/tip. This would mimic when the throttle is closed and its idling.
Also, I have no liuttle LED lights flashing on the throttle valve switch when turning on ignition so I intend to check the connections but assuming they are ok, is there a way to test this switch or do I just replace it?
Bike is running well but does idle a little unevenly and also backfires on overun when coming off the throttle quickly
thanks in advance!
thanks in advance!
- Thank you received: 2281
03 Jul 2024 05:31 #901688
by Wookie58
Replied by Wookie58 on topic GPZ1100b1 idle switch and throttle valve switch
Don't forget the basics (air leaks from hardened intake rubbers etc) it's easy sometimes to fall into the trap of "the more complex the system the more complex we expect the fault to be"
The following user(s) said Thank You: slayer61, ajh
