  • Page:
  • 1
  • 2
not charging / fuse #3 blows 14 May 2023 08:19 #884632
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
Yellow/red is power to coils on my 900/1000’s. Without seeing a wiring diagram for your bike I can only guess it’s a wired George coil relay. It would make sense the one wire would go to battery positive. Has there been a schematic posted for your bike yet?
Last edit: by Mikaw. Reason: Spelling
not charging / fuse #3 blows 14 May 2023 08:43 #884635
  • MALCOLMHOULE
  • MALCOLMHOULE's Avatar Topic Author
  • Thank you received: 2
not charging / fuse #3 blows 14 May 2023 09:02 #884639
  • MALCOLMHOULE
i’m wondering if this is the case  photo one W/R  is the positive which connects to the regulator.
Photo two Pinky is the other end ofW/R
End next to the fuse box thumb comes out of the Fuse box , splits with one side, going to the starter relay? The other side of the split is supposed to connect to the battery… I guess I’ll check Continuity?
not charging / fuse #3 blows 14 May 2023 09:02 #884640
  • MALCOLMHOULE
not charging / fuse #3 blows 14 May 2023 12:00 #884661
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2089
I hope one of the moderators will snag that pic of the wiring diagram for the P bikes as the one presently posted in the Articles section appears to be for the GpZ1100. It would be nice if KZR could get a high resolution copy of the whole P bike service manual for members to use.
Last edit: by TexasKZ.
not charging / fuse #3 blows 15 May 2023 01:35 #884693
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1890
OK the below should get you started with your power supplies from the battery (apologies for it being a bit messy, didn't have a lot of time), obviously being a "P" there is a lot of extra wiring so look carefully at the diagram before connecting anything you aren't sure about
not charging / fuse #3 blows 15 May 2023 07:42 #884708
  • TexasKZ
  • TexasKZ's Avatar
I think it would be good to remember that in addition the extra wiring Kawasaki installed on the P bikes, some departments added their own, um, creative wiring sometimes.
  • Page:
  • 1
  • 2
